Front and rear window trim
Old Aug 1, 2004 | 01:24 PM
81VetteFreak's Avatar
81VetteFreak
Default Front and rear window trim
Where can I aquire new trim that goes across the top of the windshield and around the rear window of my 1981 Corvette ?
Old Aug 1, 2004 | 01:36 PM
74Thrasher's Avatar
74Thrasher
www.madvet.com
They have just about anything you could need/want.
Old Aug 1, 2004 | 02:48 PM
81VetteFreak
Not a listing of the trim molding .
Old Aug 2, 2004 | 01:32 AM
81VetteFreak
Originally Posted by 74Thrasher
www.madvet.com
Any other suggestions anyone ?
Old Aug 2, 2004 | 01:33 AM
jetlag's Avatar
jetlag
ecklers.com is a good place also.
Old Aug 2, 2004 | 01:43 AM
81VetteFreak
No luck there either
Old Aug 2, 2004 | 07:27 AM
vetteonr's Avatar
vetteonr
Corvette Central is another place to try. Are the parts damaged, or do you just want them replaced? Mine had the flat black paint peeling off, so I just took some real fine stainless steel pads and took it off. They polish up real nice.
Old Aug 2, 2004 | 11:59 PM
81VetteFreak
My trim is bent and needs replacing .
Old Aug 10, 2004 | 02:15 AM
81VetteFreak
Anyone else know where I can aquire new window trim for my 1981 ?
Old Sep 7, 2004 | 05:51 PM
81VetteFreak
Old Sep 10, 2004 | 07:54 AM
81VetteFreak
ttt
Old Sep 10, 2004 | 09:50 AM
motorpsycho502's Avatar
motorpsycho502
I lost the upper trim on my windshield once, had to get it from a vette junkyard, piece was expensive but at least found one in good shape. I would try and refurbish what you can and replace what you have to.
http://www.corvettejunkyards.com/
Old Sep 10, 2004 | 10:11 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Mine is too, and most of the other late C3's I see have that problem.
Old Sep 10, 2004 | 10:30 AM
75 Hot One's Avatar
75 Hot One
If you can't locate an acceptable replacement piece, you can always get the one you have repaired- but that's probably expensive. Based on a couple of episodes of "Dream Car Garage" Legendary Motorcar in Milton. ON can repair trim to "as new" condition.
Old Sep 10, 2004 | 09:26 PM
81VetteFreak
Thanks guys !
To Front and rear window trim
