Steering Question
Old Aug 1, 2004 | 08:03 PM
Motor City Vette's Avatar
Motor City Vette
Default Steering Question
When I turn my steering wheel to the left, I feel a very light "notch" in the steering. It's only in this one spot and it does not seem to affect the steering. I had someone turn the wheel while I was under the car and the linkage looked fine...it didn't appear to be rubbing or hitting anything. At first, I thought it was maybe a cotter pin from the tie-rods that was bumping something when I turn. Any ideas?
By the way, it's a 1970 with manual steering.
Old Aug 1, 2004 | 09:36 PM
75 Hot One's Avatar
75 Hot One
Check the flex coupling. It could be that the bolts through the flex material are slipping and then the coupling is catching on the stop pins- this would cause about 1/8 to 1/4" free travel till it grabs again.
Old Aug 1, 2004 | 10:05 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Have you had the steering box apart? Could be a pitted spot on the gears or something else internal.
Old Aug 2, 2004 | 08:00 PM
Motor City Vette
Nope...I haven't messed with the steering box. It looks like it's relatively easy to get to...anything I shouldbe aware of if I go into the steering box (any gotchas)? Thanks!
To Steering Question
