Where to look ?
Old Aug 4, 2004 | 06:31 AM
Corvette Poor's Avatar
Corvette Poor
Default Where to look ?
In 1981 was there an option code list in the car anywhere ? I am trying to find out what options are on my car and what gear ratio is in it. I know that in later model cars G.M. has the SPO option label in the glovebox but I haven't been able to locate it in my 81.
Old Aug 4, 2004 | 07:51 AM
FinnShark's Avatar
FinnShark
C3 don't have that glove box sticker. It might be located on top of your gas tank, not an easy place just to check if it is there... It's called "tank sticker". They used to glue it there at the factory at the end of one stage. At least that's what I've heard. I've heard also stories about those papers located behind the dash between speedo and tachometer or under the drivers seat. Those are more rare places though...
You can calculate your rear end ratio by lifting the rear of the car up and calculating how many rounds propeller shaft makes when wheel makes one full round. Turn wheels by hand, don't try to do that when car is running...
