Transmission Oil
Old Aug 4, 2004 | 10:49 AM
70vert's Avatar
70vert
Banned Scam/Spammer
Default Transmission Oil
What fluid should I use in my 4 speed? Anybody using synthetic? Are synthetics compatable with old seals? What weight?
Old Aug 4, 2004 | 11:07 AM
Missileman's Avatar
Missileman
Your 1970 4 speed takes the same lube as the rear end (90 weight). Synthetics will work with the seals. I have used from 80w to 140w with no issues, but I don't like to mix weights or blends (personal preference).
Old Aug 4, 2004 | 11:28 AM
Fevre's Avatar
Fevre
When I switch to Mobil 1 syn the trans seemed to shifter a little smoother, could not tell a diff in noise over the flowmasters.
Old Aug 4, 2004 | 01:11 PM
pws69's Avatar
pws69
I also switched to Mobil 1 over a year ago. Much smoother shifting and definately quieter.
Old Aug 4, 2004 | 01:19 PM
comp's Avatar
comp
what wt. are you using
Old Aug 4, 2004 | 01:57 PM
gerry72's Avatar
gerry72
What type of lube depends on how you drive the car. If you drive it like a normal, sane person you can use a synthetic and experience a little better shift smoothness. If you do high-rpm shifting, like in a drag race, you're better off with the regular mineral oil lube. The higher your gear speed the more grip you need on the syncros and blockers. Synthetics don't provide as much grip and it can be harder and take longer to make a high-rpm shift.
Old Aug 5, 2004 | 04:39 PM
brydell's Avatar
brydell
I run Royal Purple Max-Gear 75w90 synthetic in both the Muncie and rear end with good results. I add GM anti-chatter to the rear end, and it works smoothly both hot and cold.
To Transmission Oil
