bleeder valves
Old Aug 5, 2004 | 04:13 PM
bruced267's Avatar
bruced267
Default bleeder valves
I posted a question about no brake pedal, and sounds like i ned to bleed them again in the proper order. but whats with the rear i dont rember seeing two bleed screws? do you remove it and use it ont other side?
Old Aug 5, 2004 | 04:18 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
you need to bleed both at the same time.
it would be better to buy a vaccum/brake pump.
$40.00. make a t hose for the rear calipers
Both bleeders on the same caliper, is what i mean.
on the rear.
Old Aug 5, 2004 | 06:52 PM
glen242's Avatar
glen242
There should be two rear bleed screws opposite each other on the top of the calipers. I just installed "Speedbleeders" and they work fine. Still a pain to get all of the air out, but at least I can do it myself.
Old Aug 6, 2004 | 06:47 AM
UKPaul's Avatar
UKPaul
Bleeding the rears can be easier if you raise the front of the car while doing them (or park up a hill!).
Old Aug 6, 2004 | 08:58 AM
MPSJM's Avatar
MPSJM
We are doing this today after completing a power brake conversion this week. The rear has three bleeder valves on ours two on top and one on the outside bottom. The front only has one bleeder on the iside top. Will let you know how it goes.
Old Aug 6, 2004 | 09:51 AM
Timbo2's Avatar
Timbo2
just went through this last week... I missed the inside rear and bled the others...thought I had 'em, but still NO pedeal....then read posts about proper sequence and "found" the rear inside bleeders... went through sequence and pushed out a huge air bubble on front.... man I got some brakes now! better than I had hoped.
Old Aug 6, 2004 | 09:57 AM
Timbo2's Avatar
Timbo2
forgot to say.... I just took a small aquarium hose and ran down thru a small hole in the top of a plastic soda bottle attached to the bleeder screws ...had a buddy help me pump the pedal... worked like a charm.
Old Aug 6, 2004 | 01:00 PM
glen242's Avatar
glen242
Shoddy work on the part of the rebuilder. Outside bottom should be a plug, not a bleed screw. How in hell can you get air out of a bleed screw that is lower than the rest of the caliper? This kind of workmanship would cause me to question the rest of the rebuild.
Old Aug 6, 2004 | 06:24 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
If i'm not mistaken (not uncommon for me to be) my delco moraines came with 3 bleeder screws...
Old Aug 7, 2004 | 09:21 PM
glen242's Avatar
glen242
I would be most interested in your answer concerning Delco-Moraines, as my originals had only 2 bleed screws. I still think it is shoddy work on the rebuilders part.
Old Aug 7, 2004 | 10:30 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
I'm gonna be working on the car tomorrow (detailing for Corvettes on the Square in Independence Mo next weekend -mandatory shameless plug for the KCCA ) and i will try to snap a pic for ya. When i tried to bleed them for myself the 1st time, i coulda swore that there were 2 upper and 1 lower bleeders on there, but like I said I have been mistaken before...
Old Aug 7, 2004 | 10:47 PM
glen242's Avatar
glen242
As I stated, if you have 3 bleed screws on a rear caliper, it has to be a rebuilt unit from a less than reputable rebuilder. Nowhere, in any GM manuals or literature that I have, do they show or mention 3 bleed screws on a rear caliper. As I said, how can you bleed air out of a caliper through a bleed screw that is lower than the top of the caliper??
As always, I am open to factual criticsm and comments.
Old Aug 7, 2004 | 10:58 PM
redvetracr's Avatar
redvetracr
WOW...You guys are waaay to ****, leave the "third" bleed screw alone and just bleed the two on the top.....
...redvetracr
Old Aug 8, 2004 | 12:46 AM
cw823's Avatar
cw823
I agree. Do the speedbleeders really work that well? I am in the process of bleeding mine now as I had to replace every #$@#%@#(& brake line. Of course front right caliper had the bleeder broken off. May just replace them all with speedbleeders if it's worth the cost.
Old Aug 8, 2004 | 01:10 AM
Rockn-Roll's Avatar
Rockn-Roll
A bleeder valve is cheaper than a plug.
Old Aug 8, 2004 | 01:57 AM
Z-man's Avatar
Z-man
I love mine. It takes only a couple of minutes to bleed each wheel and you're done. Plus, it's a single person job - no more begging the S/O to get in and work the brake...
Old Aug 8, 2004 | 04:49 AM
Aflac's Avatar
Aflac
St. Jude Donor '09
...redvetracr
I think it came from GM that way for some sort of universal fitment from left to right on halves...I'll look in the morning, but I think that mine do have 3 bleeders...and opening the lower one would be just short of stupid when bleeding brakes.. air goes to the top...
Old Aug 8, 2004 | 06:22 AM
saudivette's Avatar
saudivette
What's a Speedbleeder?
Are they any good? Where can I get one?
Old Aug 8, 2004 | 10:08 AM
Aflac's Avatar
Aflac
St. Jude Donor '09
They are a bleeder with a one way check valve inside them. They let fluid out and not let the air in... they work really well if your'e a one man show.
To bleeder valves
By Michael S. Palmer | 2026-06-03 11:00:24
