Crossroads..keep original or modify engine?
Old Aug 5, 2004 | 10:09 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Crossroads..keep original or modify engine?
I at the crossroads with my '72 with the 350 base engine, matching numbers, 4 speed and a 3:36 rear.
I am torn between keeping it all original...heads..exhaust manifolds etc or modifying the engine with aftermarket aluminum heads, a more agressive cam, headers, 5 quart pan etc.
I could keep the original look with the current "487X heads, the ceramic coated ram horn exhaust manifolds and go with a roller cam, different carb. Try to build horsepower and keep the original look.
I want more torque and hp....like to be at 350-375 hp and 400 ft lbs of torque.
Would appreciate everyone's thoughts.
thanks
Mark
Old Aug 5, 2004 | 10:38 PM
PRESSURERAT's Avatar
PRESSURERAT
In my opinion, I would pull the matching number engine and mothball it. Start with an entirely different motor and do whatever you wish.
joe73vette's Avatar
joe73vette
I found that as long as you keep original valve covers and air cleaner on it, most people won't know if it is modified, especially if you paint the manifold. You can make the power you are after with rams horns, too. If the car is NCRS worthy you have to make the hard choice, but nothing you mentioned is irreversable. Joe
Old Aug 5, 2004 | 10:39 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Just my opinion, but if it were mine I would mothball that engine and build a new one, or buy a crate motor. That way you will always have the numbers matching motor intact. Once you blow the motor up, the numbers matching status is gone forever.
Old Aug 5, 2004 | 11:05 PM
Gordonm's Avatar
Gordonm
Modify it. Take the old motor out and build another one to your liking. I went the original route with the LT1 and needed more power. Modified it and it is a much better car.
Old Aug 5, 2004 | 11:50 PM
Glensgages's Avatar
Glensgages
Plus tax.....
I have a lowly Cross-Fire, with just 23,000 miles, but that's exactly what I'm doing 'when' I get tired of the un-Corvette-like performance it currently delivers.
I plan-on yanking the OEM L-83/700R4 lock, stock, and barrel, and 'tagging-and-bagging' them for 'the next guy', while I enjoy my '82 as it shoulda been built.
Old Aug 6, 2004 | 08:05 AM
markdtn's Avatar
markdtn
yep Use an 86 up block with 1-piece rear seal. Should be easy to find and relatively cheap.
Old Aug 6, 2004 | 08:41 AM
mrvette's Avatar
mrvette
AGAIN, agreement, I have an '89 truck factory roller, 1 piece rear main seal block with a ZZ9 cam in it....supposed to be about 425 ft lbs, and close to 400 hp....it's enough, anyway...
also have a 700r4, which I wish was a 200 4r, but that' another story....
I also went the '88 up L98 serpentine drive....
GENE
Old Aug 6, 2004 | 09:19 AM
PRESSURERAT
GENE
Is there a hole for the fuel pump pushrod in the '89 motor? I looked into some late model blocks and they had the mounting boss the hole wasnt drilled for the mechanical fuel pump.
Old Aug 6, 2004 | 10:04 AM
markdtn's Avatar
markdtn
No, no hole for fuel pump pushrod in most of them. Either have it machined, use an electric pump, or move into the 80's and get fuel injection with an electric pump.
Old Aug 6, 2004 | 10:41 AM
JLMvette73's Avatar
JLMvette73
Ditto
Exactly what I'm doing with my '73 project. The original 350 is setting in the corner on an engine stand. I managed to latched on to a low mile, 2 year old LM1 crate motor with cast iron Vortecs, Edelbrock intake & carb and HEI ignition for $1500.00. I'm having this engine built for a "bit more" HP. I'll eventually rebuild the original 350 back to stock specifications (well, maybe not completely stock), and if the need ever arises, I can drop it back into the car.
Old Aug 6, 2004 | 10:44 AM
PRESSURERAT
If I really wanted to move into the 80's I'd get a C-4!
Old Aug 6, 2004 | 10:46 AM
Disco_Mike's Avatar
Disco_Mike
This is what several sources recommend.
there are a million chevy small blocks laying around.
but only one matching numbered block.
Old Aug 6, 2004 | 11:41 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default I hit that same crossroads
Mark
Of course my '76 was never a chrome bumper but still the thought did cross my mind. But heck, I wanted power and an L-48 just doesn't have it. I put a 4-bolt main Stroker in it, and never looked back. Same crazy thoughts when I wanted to replace the factory AM/FM Stereo.
I didn't want to make dash mods but at that time, I already had the Stroker under the hood, and modified the transmission (to make the Turbo 350 handle the power a Turbo 400 can) and put in a Stall Convertor. So I figured 'it will never be original again!' and I sold the L48 to the very first caller.
Old Aug 6, 2004 | 11:45 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Me too!
Old Aug 6, 2004 | 12:40 PM
problemenko's Avatar
problemenko
My plan is to pull the original 350 and store it. Then this winter a BB goes in. Next spring should be a blast!
Old Aug 6, 2004 | 03:14 PM
markdtn's Avatar
markdtn
That is what I did. C4 TPI motor and trans in mine. If I had it to do over it would have been a late LT1 or even LS1/6
To Crossroads..keep original or modify engine?
