Power window help
Old Aug 7, 2004 | 02:10 PM
jeaux's Avatar
jeaux
Default Power window help
while getting ready to bring my Vette to paint shop pass. side window starts acting up stuck up won't go down looks like it went to far plus I found a piece in the bottom of door Need some help I'mn having trouble posting pic will try a link
Click link below to see picture.
http://www.picturetrail.com/joaufieri
Old Aug 7, 2004 | 03:20 PM
jeaux's Avatar
jeaux
update, I got window down will work but needs help when I first pushed it down a bit it made a loud pop then a poping sound while moving I can't find a good picuture of parts, So i'm looking for help
Old Aug 7, 2004 | 03:33 PM
lostpatrolman's Avatar
lostpatrolman
If it is making a popping sound, it sounds like the window regulator might be bad. The part that has the wound up spring.
Old Aug 8, 2004 | 09:00 AM
Ganey's Avatar
Ganey
That's a cover for a PW motor. Remove motor, check & check the large gear for broken teeth. The large gear aftermarket replacements are stronger. Also check for broken PW motor mount while checking.
Old Aug 8, 2004 | 01:37 PM
jeaux's Avatar
jeaux
Could that cover be my problem cause it looks like there's some movement at the motor, some one just been in there looks like regulator is new they must of forgot to replace the cover and just put it in the door along with what looks like a lawn mower fuel filter ,also can you just change the teeth or the whole regulator?
Old Aug 9, 2004 | 08:38 AM
Ganey's Avatar
Ganey
The cover off a PW motor could cause a problem by not keeping the gears in alaignment. If there is a new regulator, then the large gear & bracket should be good. A replacement for the bracket that breaks is sold by the Vette parts venders. Symptons are a rattle when closing door & door panel flexing when first operating the PW motor.
If the large gear is bad, replacement of the whole gear is best. Note that the regulator spring is stiff so you need to be carefull & watch out for your fingers.
To Power window help
