Headlight Help
Old Aug 7, 2004 | 02:36 PM
Wife'sVette's Avatar
Wife'sVette
Default Headlight Help
I will listen to all advice..........."77 L-48
the wonderful problem of the headlights not going up or down.......
the lights turn on and I can raise and lower manually, but not by themselves.... here is what I have done so far:
1. removed headlight switch, seems to work fine...... on/off as far as the vaccum part goes
2. checked little bleed off valve below dash........ seems to shut off good, no leaking
3. tightened manifold vacuum T .. behind carb .... and replaced the short hoses
not knowing alot about these cars, if I can take off one of the vacuum lines from the vacuum "switch" under the front of the car and blow in the lower one the light will raise, blow in the upper one and the light will lower,(or vice-versa, can't remember) does this mean the actuators are good? If so, what else do I need to check? ......Thanks, Robert
Old Aug 7, 2004 | 02:48 PM
73'Vette's Avatar
73'Vette
This is what I used to fix my headlights.
http://www.corvette-101.com/
Old Aug 7, 2004 | 03:10 PM
Wife'sVette
Default great
Thanks, looks like a good place to start and, hopefully, finish .......Robert
Old Aug 7, 2004 | 04:16 PM
lostpatrolman's Avatar
lostpatrolman
I have a 10 page pamphlet called Troubleshooting 1968-1982 Corvette Headlight and Wiper Door Vacuum Systems. I could scan it and send it to someone if they want to post it on a website or something.
Old Aug 8, 2004 | 03:41 AM
Cajun99's Avatar
Cajun99
Originally Posted by Wife'sVette
...what else do I need to check?
Make sure this check valve is not leaking and working properly...if it leaks it can wreak havoc on the light's operation. Make sure your air filter in front of it is clear too...the white piece.
Old Aug 8, 2004 | 04:11 AM
i885744's Avatar
i885744
I'll host it on my site, would be a handy resource to all. COrvettefaq.com might want it too. email me, mikecooki885744@hotmail.com and i can put it on no problem.
To Headlight Help
