First Impression...BTO 200r4 Trans
It wasn't realised when we installed the tranny, but the furthest aft pan bolt is over the crossmember which meant taking that loose and aft. When we replaced the pan we cut the bolt 1/8" short and now the pan can be removed without loosening the crossmember again.The shifts are much softer than I expected. Normal around town driving, I simply cannot feel the shifts. Giving a little playful throtle then the shifts are felt, but again, softer than expected. The RPM's barely drop between shifts. Bow Tie said I should have firm shifts, but no explanation was given for how mine feels.
I might not have the TV cable adjusted perfectly because at normal townie under 40 mph driving it shifts into OD at about 25 MPH. I called Bow Tie on this and they said, it's a performance tranny and I should use drive 3 (1-1) around town and shift to OD for long stretches above 45.
Needing a trans cooler is yet TBD. The tranny temp gage they sent and insisted on installing for the warranty is temporarily mounted just forward of my ashtry. If I decide to keep one it will be an Autometer gage and in a pod.
Anyway, so far I'm not sure this was worth it. Over time I can give a better owners evaluation.
GENE
GENE
