Who has this power steering problem?
Old Aug 7, 2004 | 08:00 PM
Brown78's Avatar
Brown78
Default Who has this power steering problem?
In the past four years that I've been working on this Vette project. I've had to replace or repair the power steering return line at lease 5 times. First time I replaced with a new line. The hose cracked at the hose clamp. So I cut off the hose and bobbed the end of the tube. That lasted a while. Then bought another new return line. lasted awhile, then leaked. There isn't any pressure on that line. I've made the hose a little longer and it still cracks and leaks at the clamps Any Ideas????
Old Aug 8, 2004 | 12:15 AM
Disco_Mike's Avatar
Disco_Mike
headscratchingsmilie.
are you sure you have the lines on the proper sides of the steering ram?
Old Aug 8, 2004 | 07:16 AM
mrvette's Avatar
mrvette
Are you using ATF for power steering fluid??
years ago using ATF worked fine, but these daze something has changed, and it's no longer good for power steering, something attacks the rubber and makes it fail/leak....
gotta use dedicated power steering fluids....
stupid, I know....
GENE
Old Aug 8, 2004 | 11:55 AM
samurai's Avatar
samurai
For some reason, I also get a leak every couple of years in my power steering hose - I have replaced it three times now. I will try the suggestion not to use ATF - maybe it is chemically devouring the hose over time, who knows !
Old Aug 8, 2004 | 01:25 PM
Jim Shea's Avatar
Jim Shea
Could you be clamping the hose too tight? This assumes you are using screw type hose clamps. The Chevrolet Overhaul Manual says the screw clamp should be torqued to 26 in-lbs. Then rechecked after a couple days. (26 in-lbs ain't much!)
Also, I do recommend that you use GM power steering fluid.
Old Aug 8, 2004 | 04:15 PM
Brown78's Avatar
Brown78
stupid, I know....
GENE
Thanks Gene, I think thats what my trouble is. I was at the track when the hose broke the first time. The only thing I could find was AFT I remember using that back in the early 70s. And it worked fine. Never thought about it again. This time I put in power steering fluid. If it ever leaks again I'll post it.
To Who has this power steering problem?
