Pros and cons for gear-drive timing set
Old Aug 9, 2004 | 01:02 PM
mrcorvette79's Avatar
mrcorvette79
Default Pros and cons for gear-drive timing set
Just wondering if anyone is running any of the popular gear drive timing sets available from Jete Jackson or Edelbrock. I know they're probaly overkill but I can't get over the blower whine they make. Are there any drawbacks by using these, horsepower reductions etc.
Thanks, Marc
Old Aug 9, 2004 | 01:36 PM
Wrencher's Avatar
Wrencher
Ran a Pete Jackson dual idler in my '64 GTO.
pro: great gear whine!
con: terrible gear whine!
Some days I loved it, but it got old really fast...
Old Aug 9, 2004 | 01:44 PM
Corey_68's Avatar
Corey_68
It's a novelty for a week, after that you'll HATE it.
Old Aug 9, 2004 | 01:45 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I run the P. J. "quiet" drive on my small block...tho some say they transmit harmonics to the valve train, cause global warming, kill baby seals, contribute to male patern baldness etc. etc.
I'll be the first to admit a quality chain drive is more than reliable, but hey, I'm a street rodder at heart and the sights and sounds that go with it make it all the more
Old Aug 9, 2004 | 01:46 PM
Twin_Turbo's Avatar
Twin_Turbo
I've got Milodon drives on my engines, they are the thigns that come as a cover w/ the idler in it.
Old Aug 9, 2004 | 01:47 PM
munday's Avatar
munday
I have a pete jackson gear drive..loud as hell. annoying when under the hood. fun when nailing it. can't hear over about 30 mph, under that it's loud
Old Aug 9, 2004 | 01:51 PM
norvalwilhelm's Avatar
norvalwilhelm
I have the gear drive in the mustang and like Corey after week I wish I never put it in. Also sometimes they can be difficult to install.
Give me a double roller chain anytime.
Old Aug 9, 2004 | 01:58 PM
munday's Avatar
munday
forgot to add, i will not buy another one. if I knew how I would put my double roller back in.
anyone want a gear drive? put in my roller and we can work something out.
Old Aug 9, 2004 | 03:02 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
100%
Old Aug 9, 2004 | 03:15 PM
wugak's Avatar
wugak
Default Not for me
I drove a vette with one while I was buying. The owner claimed he always got questions about wether he had a blower hiding under the hood. I think the question was more like "what the heck is wrong with your engine?" Sounds very weird.
Cons = weird noise
Pros = ??? anything ? I guess I've never broken a timing chain...
Old Aug 9, 2004 | 04:04 PM
munday's Avatar
munday
i remember and article by david vizard saying they are useless except in high output race motors where there are no idlers and the engine turns backward. you need a special cam, i think he said some stock cars do this.
Old Aug 9, 2004 | 04:19 PM
Twin_Turbo's Avatar
Twin_Turbo
Vizard must be talking about the gear drive system with no idlers, you need a reverse rotation cam for that, amongst other stuff.
Old Aug 9, 2004 | 04:28 PM
stingr69's Avatar
stingr69
I had one many years ago back before Pete Jackson had a choice of quiet or loud. Not a big deal but all it does is sound like you are out of power steering fluid.
I heard one at the track a few years ago and I am glad I did not use one in my engines since the first one. It just screams "hey, I got an extra $100 so I thought this would be cool". Almost like ricers with lots of stickers. Well maybe not quite THAT bad but about as useful.
I used a GM all steel gear set and chain from the HD parts book this last time. What else would you ever need? JMO
-Mark.
Old Aug 9, 2004 | 04:29 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
is it more accurate at speed, for high revving motors? thats the only thing I can think of.
Old Aug 9, 2004 | 08:36 PM
mrcorvette79
Great thoughts from everyone, appreciate the comments. You all are right once I thought about it. I was just remembering back to my earlier years when one of my friends let me drive his 35 Chevy Master Coupe equiped with gear drive. On that car it worked with the whole image of the car but like Stingr69 said it would be like the ricers and there fast stickers. I'd rather use that $ 100 bucks towards a new set of cylinder heads.
Old Aug 9, 2004 | 11:34 PM
munday's Avatar
munday
I can't remember if it was Vizard or Yunick that talked about how they were useful around 7k + rpm because one of them did a test where they had a clear (maybe plexiglass) timing cover and at that speed, the chain would jump gears and looked like it was about to rip apart.
Old Aug 10, 2004 | 02:56 AM
Schmucker's Avatar
Schmucker
One of the problems I hear about is it can cause about 4 degrees of timing change. That's fine for alcohol motors as they aren't as sensitive to timing, but that is kinda a big change for a gas engine. That's why I wouldn't run it. If you the two gear, no idler setup it'd be better. You'd need a reverse rotation cam and distributor. Probably something with the oil pump as well. The came could probably be custom ground, and their are some big blocks that had a reverse rotation distributor for some reason, and those can be used in a small block. It's possible to piece it together, but it's really not necessary.
Old Aug 10, 2004 | 08:55 AM
Willis's Avatar
Willis
Something that nobody has mentioned is the fact that the noise produced by that wonderful whine will make a knock sensor go nuts. If you have or plan on using a fuel injection setup you do not want a gear drive cam.
Old Aug 10, 2004 | 10:00 AM
Ganey's Avatar
Ganey
Use a roller timing set on the street. Gear drive transfers harmonics to the valvetrain. If gear drive was a good idea on the street would have been using it on the street for many years. The best gear drive is 2 which requires a reverse rotation cam. GM even offered a 2 gear rev. setup w/ the coated gear for the L-88 !
Another thing to note is that the Chevy chain is very short compared to an OHC setup.
"I can see no reason to use a gear drive in any sort of high-performance street engine." Smokey Yunick
To Pros and cons for gear-drive timing set
