I am looking for a classic daily driver. I have found a 76 350 auto that I can get for 3500. It starts but it has been sitting for 10yrs. the brakes dont work and the radiator is shot. Paint in not great but complete and could be buffed to a decent shine. The front bumper is in pieces. The lights are stuck up and missing the vacuum motors. It has the original motor and has 70K miles. It also has a nonfacory spioler bonded permanently on the trunk. the interior is passable and the dash pad is cracked but ok for a driver.
if I buy this for 3500, what can I expect to pay to get the car in daily driver shape?
Are there hidden things that can be wrong that would make this a bad buy?
What could I expect to sell this for in 5 years if all was in order?
Make sure the frame is in good shape. See if you can spend a few grand more and get a car in better shape. You realize that it's going to cost you at least $1500 to get this car going (Rad, brakes, front bumper) so your cost right now is $5000 for the car.
I'm sure if you keep looking you can get a pretty decent car that you can drive right away for 5K and fix it up here and there while still driving it. This might save you a few headaches. If you have your heart set on this particular car, then check the frame. Good luck.
we just bought a 77 for 7000, a bit much, but it is in great looking shape and only need a few things (a/c and head... no, fixed the headlights last night without spending a dime (rebuilt vacuum relays) 90,000 miles .. hope this helps.....Robert
Good advice you were given about checking the frame. Even worse then the frame is the windshield frame and rocker channels. I believe those are the first places to rot out on any C3 because the steel is a lot thinner. fitting new bumper covers is no easy task either, especially the front. Check out the 3rd page of my web site, you'll see what I mean, or read about the project (and what you could be getting into) here: http://www.crossedflags.com/nuke/htm...howpage&pid=24
i bought my 77 over a year ago when i got it wasnt running the cailpers were froze up needed new brakes calipers interior was shot had 2 put 2 new deluxe door panals on it witch is another 800 bucks new carpet windsheild was leaking leaked on the fuse box it became rusty put a new 1 in it car had warped headers on it took them off bought some manfolds which r not cheap 2 get had 2 reroot wires on the engine had carb rebuilt had replace valve covers
