Which Rapid Fire plugs for my engine?
Old Aug 10, 2004 | 12:06 AM
PartTimeGenius's Avatar
PartTimeGenius
Default Which Rapid Fire plugs for my engine?
I did a search on "Rapid Fire" pliugs and found that most Forum users experienced a slight increase in power, smoothness or better emissions.
Since I could use all three, I'd like to know which Rapid Fire would be the best for my ZZ3 with aluminum Twisted Wedge heads (daily driver).
Thanks!
Old Aug 10, 2004 | 07:30 AM
EDDIEJ82's Avatar
EDDIEJ82
I'm running the KD's on mine and use the Rapid Fire 5's. I like them alot.
Old Aug 10, 2004 | 09:11 AM
1970 Dave's Avatar
1970 Dave
I installed a set of Rapids Fire #7's in my 70 350 on Sunday and there was a noticeable difference in the start and the smoothness of the idle. How much was just a new set of plugs and how much was the Rapid Fires--who really knows--but it made me feel better and thats what counts
SEMPER FI--1970 Dave
Would like to get a "free shot" at the genius who came up with the layout of ignition shielding
Old Aug 10, 2004 | 09:33 AM
Crash80's Avatar
Crash80
The Rapid Fires will run you about $4.50-$5.00 per plug. The rule of thumb is that the higher compression motors generally will require a colder plug. Here is great article explaining heat ranges and the like.
http://www.ngksparkplugs.com/techinf...000&country=US
Old Aug 17, 2004 | 03:24 PM
RMK's Avatar
RMK
Are the rapid fire 5's a platinum plug?
Old Aug 17, 2004 | 03:27 PM
RMK's Avatar
RMK
Are the Rapid fire 5's a platinum plug?
Old Aug 17, 2004 | 04:03 PM
Crash80's Avatar
Crash80
I don't believe any of the Rapid Fire plugs are platinum.
Old Aug 17, 2004 | 04:12 PM
RMK's Avatar
RMK
Thank you sir. I'm having issues with my car anbd just wanted to be sure that I wasn't running platinum plugs with my MSD box that were crapping out on me.
Old Aug 17, 2004 | 09:35 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
rapid fire 10's here. does anyone know what the number represents?
Old Aug 17, 2004 | 09:57 PM
kdf1986's Avatar
kdf1986
Default Rapid Fire Plug cross reference
Hello,
I looked up the Rapid Fire numbers on the following website:
http://www.gmpartsdepot.com/sparkplug_chart.html
The numbers cross reference AC Delco spark plug numbers. For the Rapid Fire number 10, it is compatible with the following AC Delco spark plug numbers.
Rapid Fire 10 = R44T, R44TX, R45T, R45TX, R43T,
MR43T,MR44T, R43T6, R46T6
Old Aug 17, 2004 | 10:35 PM
Crash80's Avatar
Crash80
I would assume that the number represents the heat range of the plug. I don't know for sure which way is which though. You would assume that a 10 is hotter than a 2...but maybe it is the other way around.
Old Aug 20, 2004 | 04:48 PM
Southern Comfort's Avatar
Southern Comfort
I went to the AC Delco site for Rapifires and my 85 requires a
#1.
To Which Rapid Fire plugs for my engine?
