rear diff. fluid- GM or other addative?
Old Aug 11, 2004 | 12:38 PM
Evil_1979's Avatar
Evil_1979
Default rear diff. fluid- GM or other addative?
Ok, I am changing the rear diff. fluid on Saturday. Sould I get the GM addative for limited slip? The bottle of mobil 1 synthetic claims to have addative in it. Also Autozone had limited slip addative that is supposedly GM approved.
Should I still get the GM addative (from GM)? I think I have heard I should stick with GM, but what can those who have done this tell me?
Thanks!
~Kevin
Old Aug 11, 2004 | 12:47 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I have about 40,000 miles on the Mobil 1 diff oil in my Vette. I put it in straight, no additives and have had no problems. The posi still works fine. Did you do your 5 tight 360 degree turns in both directions after the oil was changed?
Old Aug 11, 2004 | 12:52 PM
GaryS's Avatar
GaryS
GM additive and Mobil 1 syntthetic lube in my differential. I would only use the GM brand of posi additive. Just my $.02 but you did ask.
Gary
Old Aug 11, 2004 | 03:50 PM
marshrat99's Avatar
marshrat99
My diff was making noise last year so I changed fluid and added the GM additive. Noise solved. I did not use Mobile 1.
Old Aug 11, 2004 | 03:53 PM
Evil_1979's Avatar
Evil_1979
Yeah, mine has started making noise recently. May have something to do with all the autocrossing (not to mention empy parking lot autocross "practice") I've been doing.
I think I will go for the mobil 1, if noise persists drain a little out and add the GM additive.
If that doesn't help it will have to wait for October I'll pull apart the rear end.
Cheers!
~Kevin
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Either one is fine.
Old Aug 11, 2004 | 04:40 PM
burners's Avatar
burners
Cruise-In V Veteran
Kevin, my clutches were chattering when turning corners. That is why I changed the oil. The new oil (and the tight turns to work it into the clutches) solved the problem.
Old Aug 11, 2004 | 04:45 PM
comp's Avatar
comp
NAPA's add. is from same supplier
Old Aug 11, 2004 | 05:26 PM
Evil_1979's Avatar
Evil_1979
Thanks guys!
I'll be trying this on Saturday and will keep you updated.
If I'm really lucky my new Hooker headers will be here by then as well (the sidepipes came today).
~Kevin
Old Aug 11, 2004 | 05:53 PM
comp's Avatar
comp
don't forget PIC's
Old Aug 11, 2004 | 09:14 PM
Wrecked82's Avatar
Wrecked82
Originally Posted by Van Steel
Either one is fine.
Of course. You think the differential knows what type of fluid is in it?
Some one, HELP!
Old Aug 11, 2004 | 11:22 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
I heard that I should change the fluid with additive, drive with tight turns then redrain and refill with fresh fluid and additive.
Is changing the fluid twice necessary?
To rear diff. fluid- GM or other addative?
