Tie Rod Ends (HELP!!!)
Old Aug 11, 2004 | 06:48 PM
70L46Conv4Sp's Avatar
70L46Conv4Sp
Default Tie Rod Ends (HELP!!!)
I'm finally putting my new front suspension back together and just noticed the tie rod ends have an R or an L on them. Does this mean both L's go on the left side of the car or does it mean an R and an L on each with the R on the right and the L on the left???
Thanks,
Claude
Old Aug 11, 2004 | 07:05 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
you could call the place you bought them from
Old Aug 11, 2004 | 07:24 PM
comp's Avatar
comp
it also may mean left or right hand threads
Old Aug 11, 2004 | 07:45 PM
70L46Conv4Sp
They came from Muskeegon Brake. I was hoping to install them tonight, but I'll wait until tomorrow when they're open and call if nobody can answer this tonight. Thanks.
Old Aug 11, 2004 | 09:15 PM
redvetracr's Avatar
redvetracr
Be brave!!! "try" one of each on each side...Might just work..
...redvetracr
Old Aug 11, 2004 | 10:00 PM
norvalwilhelm's Avatar
norvalwilhelm
The L stands for left hand thread and it goes to the outside or connected to the steering arm. The R are right hand thread and are used on the inside or the drag link.
So on each side use a L and a R. If you put two L's or R's on the same tie rod sleeve the steering will not be adjustable.
Old Aug 11, 2004 | 11:30 PM
Jim Shea's Avatar
Jim Shea
Norval is correct. If a picture helps to make it a bit clearer, you can download the following:
http://www.corvettefaq.com/c3/Adjust...d%2014FE04.doc
Old Aug 12, 2004 | 12:22 PM
70L46Conv4Sp
Thanks guys. I wrestled with this while tossing and turning last night and it hit me that it wouldnt adjust with the same threads on one sleeve. Actually, it would adjust but it would remain the same length. I can't wait to get the ole C3 back in commission. It's been a long time and I've enjoyed driving my Austin Healey a lot but the Vette is really in a different fun class. Doing your own work certainly has it's rewards. It gives you a fresh perspective on how things work and an appreciation of the car you'd never have when farming the work out. I've been doing the mechanical work on my old cars for many years but this is my first suspension job except for the occasional change of shocks.
Old Aug 12, 2004 | 01:02 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
not only will it not adjust right but the tie rod end will not thread correctly into the sleeve if you have them backwards.
To Tie Rod Ends (HELP!!!)
