Engine noise now and then
Old Aug 13, 2004 | 02:44 AM
vttedrm's Avatar
vttedrm
Default Engine noise now and then
I've got his ticking noise coming from my engine but only after I reach about 2000 rpm. Idling you don't hear anything. And at 3000 rpm it's like a train on the tracks."..tic tic tic / tic tic tic / tic tic tic.../.
Logic says it can't be drivetrain since it only starts over a certain rpm? Any ideas? It's so dam* annoying! Thanks.
Old Aug 13, 2004 | 09:19 AM
Steve's74's Avatar
Steve's74
Sounds like either an exhaust tick or a hydraulic lifter ticking. It's possible that a rocker arm nut has backed off enough that the lifter can no longer compensate, adjustment may be needed.
Old Aug 13, 2004 | 09:22 AM
Boofers's Avatar
Boofers
that it could be an exhaust leak. Check your header gaskets for a blow-by.
Old Aug 14, 2004 | 02:28 AM
vttedrm's Avatar
vttedrm
The exhaust system is about 2 months old (real duals with headers). Wouldn't it tic at idle also if it was an exhaust leak? I've tightened the bolts. It does seem to come from underneath the car. Thanks guys. I'll check both options.
Old Aug 16, 2004 | 10:12 AM
Boofers's Avatar
Boofers
I have experienced blown header gaskets at the manifold as well as at the collector. I tried tightening the bolts and it didn't fix it until I replaced the gaskets. As soon as I pulled the bad gasket out I saw right away where the leak was. I found the gaskets that came with my headers did not last that long. Now I have Ultraseal gaskets on, time will tell how long they last...
As for the lack of tick at idle I had the same thing, it was like it only ticked when the engine was under load. Not ticking at idle probably means its not valvetrain related which is good. Changing gaskets is easy, a good thing to rule out before you dig into your engine.
I have had my dual stainless exhaust for just over a year now. I had exhaust leaks where the cat met the pipe. I could hear it, I could see the black residue on the pipe and I could feel the exhaust leak with my fingers with the engine running. I had to tighten the clamps. Good Luck!
Old Aug 16, 2004 | 10:28 AM
PRESSURERAT's Avatar
PRESSURERAT
I had my car do something very similar once........I was used to the sound of leaking headers and was sure that's what the problem was. It was dark out and curiosity got the best of me, so I opened the hood to have a look. What I found was a bad plug wire arc-ing to a header bolt. I was running a high energy ignition system at the time. Man was it ever loud!
Old Aug 17, 2004 | 02:22 AM
vttedrm's Avatar
vttedrm
Thanks for the help guys. This forum is great! I'll pick up some gaskets and check it out. I'll look into the plugs as well. Thanks again.
Old Aug 17, 2004 | 01:21 PM
stingraymaniac's Avatar
stingraymaniac
mine was like that last weekend when i had been at the track dragracing
really loud ticking noise around 2000 rpms and up.
turned out too be a header gasket.
To Engine noise now and then
