Tranny gasket question [pics]
Old Aug 14, 2004 | 10:08 PM
77Dream's Avatar
77Dream
Default Tranny gasket question [pics]
I have had a tranny leak for awhile and thought I would try to tackle that problem today. I bought a gasket and filter kit and an O-ring for the dipstick tube. I pulled the pan and found that whoever put in back on last used allot of RTV or something. I always thought you shouldn't use that stuff because it could easily get into the tranny and clog it up. What do you guys think? Here are some pics of the pan:
http://www.77corvette.com/posts/DSC00890.jpg
http://www.77corvette.com/posts/DSC00889.jpg
http://www.77corvette.com/posts/DSC00892.jpg
Looks like a bubba job to me, but I also don't know much about transmissions.
Old Aug 14, 2004 | 10:38 PM
page62's Avatar
page62
BUBBA WUZ HEER! Yup, that's some pretty nasty work. Your gonna have to clean all the crud off. Then take a ball peen hammer and carefully flatten the bolt holes on a convenient flat surface. Don't overtorque when you put it all back together. Fresh bolts & lockwashers never hurt, either.
Old Aug 14, 2004 | 10:46 PM
comp's Avatar
comp
And i wish people would learn,,,The chemicals in RTV break
down the glue in the cork gaskets... so over a time they are Making a
leak.... i've used rtv on trans pans, put it on and let it skim over and
don't pour it on
Old Aug 14, 2004 | 11:25 PM
77Dream's Avatar
77Dream
Hmmm.... Here is the filter that was in it, notice the little gasket has silicone on it too. Also, the particles that it has collected, is that alot? Or is that normal? Maybe a sign of abnormal wear?
http://www.77corvette.com/posts/DSC00897.jpg
Old Aug 16, 2004 | 12:10 PM
77Dream's Avatar
77Dream
So after smashing about 4 knuckles trying to get the dipstick tube pulled out enough so I could replace the o-ring I have made things worse. I managed to put a little hole in the tube right above were it goes into the tranny. At the time I thought it wasn't that big of a deal. I went down to the local auto parts store and found a nice looking chrome dipstick and tube. Sweet, just pull the old one out and slide the new cool looking one in and I'm all done. The problem is I can't get the old one out. Now I could just break or cut it into 2 pieces and get it out easily, but then how would I get the new one in? Those tubes have bends in them that make it so you cant just pull them out no matter how you twist and turn it. I'm thinking I'm going to have to disconnect the motor mounts and try to move the motor over just a little to give me some more wiggle room. What do you guys think? Has anyone here replaced the dipstick tube with both the motor and tranny in place?
Old Aug 16, 2004 | 12:48 PM
GTR1999's Avatar
GTR1999
You might want to add a drain plug kit to save you time in the future. I used a skim coat of RTV on the pan side of the gasket to hold and seal it. I used the Permatex Gray RTV. It's all setup and the tranny is sitting on the stand so by the time any oil comes in contact with it there should be no problem.
This is a TH400 pan but you can use the kit on Th350's too. Not NCRS though!
Gary
Old Aug 16, 2004 | 12:55 PM
77Dream's Avatar
77Dream
Gary, I hadn't thought of adding a drain plug. It's a great idea, I made a mess when I removed the pan. I'll get one of those plugs on my way home from work today.
Old Aug 16, 2004 | 12:57 PM
GTR1999's Avatar
GTR1999
It will save you a big mess when you change the next filter. This is one that came in the Th400 B&M rebuilt kit,but it's not much so you should be able to make one up.
Gary
Old Aug 16, 2004 | 10:11 PM
LiveandLetDrive's Avatar
LiveandLetDrive
My trans has leaked since I got the car, did a rebuild this weekend and just used straight cork, no leaks
Old Aug 16, 2004 | 11:52 PM
77Dream's Avatar
77Dream
My plan is to use nothing but cork. Just rub a little tranny fluid on it so it seals good and holds in place while I install.
Old Aug 17, 2004 | 12:49 AM
EVIL_GRIM's Avatar
EVIL_GRIM
if you have a Tognotti's Auto store near you go there and ask for a Cast Alluminum pan, it has about 3/8 inch flange on it and wont warp or anything, i love mine, except.. I CANT FIND WHERE MY TRANNY IS LEAKING!! it looks like the front of the friggin pan! argh!
Old Aug 17, 2004 | 07:28 AM
70_Shark's Avatar
70_Shark
There should be enough wiggle room to get the tube in and out with engine/trans in place, at least I can do it with my BB/TH400. Two quick notes. First make sure the aftermarket dipstick is the same length for accurate measure and second sometimes the leak is not from where you expect it. I had a front seal leak which ran very sneaky down the top lip of the pan and dripped back by the mount. Good luck.
To Tranny gasket question [pics]
