Help ordering phnelic gasket
Old Aug 15, 2004 | 11:16 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Help ordering phnelic gasket
Going from torquer II to a performer which is shorter. Looking for phenelic gasket. go with 1" or 1/2"? Application with a Eldebrock model 1400 carb. Open plenum or 4 hole, 1/2" or 1"????
Space your carb for more performance.
Holley/Carter/Edelbrock: Square bore, four-hole design, 1 in. thick, carburetor spacer
This precisely designed Mr. Gasket carb spacer provides a smooth transition of air and fuel from the carburetor to the intake manifold, to increase flow for more performance. Its phenolic resin also helps insulate the carburetor from engine heat and provides clearance for linkages. All attaching hardware and gaskets are included.
Sold individually.
Vendor Mr. Gasket Co.
Product Line Mr. Gasket Carburetor Spacers
Material Phenolic Resin
Finish Black
Height 1 in.
or
1/2 in. thick, open plenum, square bore mounting surface, phenolic, carb spacer
This phenolic carb spacer offers many advantages. It'll extend the length of the intake mixture column to improve air/fuel distribution and reduce the fuel temperature inside the carb, resulting in a denser, more powerful fuel charge. It'll also help with linkage clearance when using custom throttle setups. It features a 1/2 in. thickness and an open plenum design. Gaskets and mounting hardware are included.
Sold individually.
Vendor Summit
Product Line Summit Plastic and Phenolic Carb Spacers
Height 1/2 in.
Old Aug 16, 2004 | 01:32 AM
71coupe's Avatar
71coupe
The Performer p/n 2101, is not that much shorter than the Torquer 2 - like .03". If a spacer will fit, go with the open style.
Here's Edelbrocks page
http://www.edelbrock.com/automotive/index.html
Old Aug 16, 2004 | 08:15 AM
Ganey's Avatar
Ganey
Probably you want the divided spacer. Edelbrock has a thin .320" for the Carter carbs like you have #9266 divided (also #9265 open).
Old Aug 16, 2004 | 09:25 AM
Cali,68,L-79
Thanks guys but I cannot find the part 3's you've submitted nor does their sight have a search mode to input those numbers?????
Old Aug 16, 2004 | 12:30 PM
PRNDL's Avatar
PRNDL
Select "carburetors" from the menu on the left, then select
Carburetor Adapters and Spacers
, and you will get the right page... (cant link it.. )
maybe this is it...
http://www.edelbrock.com/automotive/install1.html
Old Aug 16, 2004 | 01:56 PM
Cali,68,L-79
Yeah found that but can't find numbers 9265/ 9266.
Old Aug 16, 2004 | 02:22 PM
PRNDL's Avatar
PRNDL
Other parts:
>Home >Carburetor >Carburetor Heat Shield >Performer Series; Heat Insulator Gaskets
Click on the part number to view images and product details.
Part # Description
9266 Performer Series; Heat Insulator Gaskets; Divided Square Bore; 0.32 in. Thick; "Universal Fit"
9265 Performer Series; Heat Insulator Gaskets; Square Bore; 0.32 in. Thick; "Universal Fit"
9267 Performer Series; Heat Insulator Gaskets; Square Bore; For Dual Quad Manifold; 0.125 in. Thick; "Universal Fit"
(I guess you don't need 9267 = dual quads! )
Top left - "find parts by vehicle"
click on "show me products that are not vehicle specific"
carburetor
carburetor heat shield
also, on summitracing website identify parts as EDL-9265
Old Aug 16, 2004 | 02:51 PM
Paul L's Avatar
Paul L
I used the #9266 as per Ganey's advice. No problems with heat boil.
http://www.edelbrock.com/automotive/...s.html#gaskets
Old Aug 16, 2004 | 03:56 PM
Cali,68,L-79
Paul I'd love to get yours but I have a single plane.
Old Aug 16, 2004 | 09:53 PM
Ganey's Avatar
Ganey
Originally you said you were going to a Performer intake.
Old Aug 16, 2004 | 10:14 PM
Cali,68,L-79
Yep changed pans in mid sentance...sorry.
To Help ordering phnelic gasket
