Shopping list.....thoughts?
Aug 17, 2004 | 09:12 AM
Well, I need to order the some items to finish my build up.
Reference : 383 short block assembled w/balancer and flexplate, HR cam 227/234, TFS heads, Performer 1405 Carb, 1.5 RR, gaskets, etc.
Needed items and suggestions on the following items...................
Headers (w/ Alt and A/C brackets):
Dynomax ceramic
Water pump:
Intake:
Performer
Performer EPS
(I just don't think I can get the RPM to fit.)
Air Cleaner:
Something with 1 1/4" drop base
Torque converter:
B&M 2000
Fuel Pump:
Odds and ends:
Intake manifold bolts
Header Bolts
Fuel line
Carb studs
If anyone has any suggestions or something I'm forgetting that would be very helpful.
Aug 17, 2004 | 09:15 AM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Aug 17, 2004 | 09:26 AM
Hoses and clamps.
I used Aeroquip fittings and hose for my upper fuel line.
Summit has carb stud kits. Bolts work fine, too.
I got some 12-point stainless intake bolts from ARP, through Summit. Real nice.
I went with Stage 8 stainless locking header bolts, again from Summit. Pricy, but hopefully worth it.
Still building. Hope to finish this weekend.
Race ya!
Aug 17, 2004 | 10:18 AM
Aug 17, 2004 | 06:21 PM
Any particular motor mounts?
Aug 17, 2004 | 06:36 PM
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Don't forget all the chrome goodies
Aug 17, 2004 | 06:43 PM
Which distributor are you using? Don't forget the fuzzy dice...
Aug 17, 2004 | 07:12 PM
Energy Suspension mounts. Poly.
Aug 17, 2004 | 09:46 PM
Man what was I thinking.............
Aug 18, 2004 | 07:16 AM
Don't forget the digital camera so you can post photos of the project.
