Thermostat?
Old Aug 17, 2004 | 01:48 PM
federij's Avatar
federij
Default Thermostat?
Please excuse me for being dumb but while looking over my vacuum lines around the air cleaner I noticed two hose connections attached to the thermostat on my 1980 and one of them is broken and Im having a heck of a time trying to find a replacement because I dont know what it is.Also a similar connection leading from the EGR valve.Does anyone know what these little gadgets might be called?
Your help is greatly appreciated!
Old Aug 17, 2004 | 01:56 PM
Paul L's Avatar
Paul L
They are called thermal vacuum switches (TVSs). One (on the intake) is for the EGR as you have noted. The unit on the t-stat housing is for the early fuel evaporative (EFE) system: controls the heat riser on the passenger side exhaust.
Old Aug 17, 2004 | 02:08 PM
federij's Avatar
federij
Thanks for your help!
Old Aug 17, 2004 | 04:55 PM
marshrat99's Avatar
marshrat99
They're color coded so be sure to let your parts person know what color you're replacing.
To Thermostat?
