Drilling thru stainless steel....
Old Aug 17, 2004 | 04:12 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Drilling thru stainless steel....
Do I need a special drill bit?
Old Aug 17, 2004 | 04:13 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
not sure.. interesting av though
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
it's not necessary, but you better have a good one....
Old Aug 17, 2004 | 04:16 PM
Twin_Turbo's Avatar
Twin_Turbo
Make sure you have a sharp one, use cutting/drilling paste or oil (is it called that?) and center punch the hole. With blunt bits the hole will get real ugly.
Old Aug 17, 2004 | 04:20 PM
Schmucker's Avatar
Schmucker
It tends to work harden, just have a good bit and use oil.
Old Aug 17, 2004 | 04:22 PM
NHvette's Avatar
NHvette
As others have said - a good sharp high speed steel bit (cobalt ?) and some lube.
Also, start small and work up to the larger diameter.
I use a tapered ream to clean up drill holes in thin stock - up to about 1/2" diameter hole.
Old Aug 17, 2004 | 04:25 PM
norvalwilhelm's Avatar
norvalwilhelm
Good sharp drill, cutting fluid and slow speed and it is no problem.
Old Aug 17, 2004 | 04:32 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
NH Vette there you go Cobalt is the only type of drill to use for hard stuff. They are expensive but they work like a regular drill going through wood.
Old Aug 17, 2004 | 05:22 PM
Gordonm's Avatar
Gordonm
A carbon drill will do it but it will dull out quickly. A cobalt drill will do the job much better. Use a slow speed and keep pulling a chip. S.S. will work harden quickly if you use to much speed or don't keep penetrating. Use a good cutting fluid and you should have no problem.
Old Aug 17, 2004 | 05:46 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
totally true
Old Aug 17, 2004 | 06:02 PM
71roadster's Avatar
71roadster
do NOT start small and work up. This only causes stress on the larger drill bit and will cause the hole to be less round as well as ruin the edge ogf the larger drill bit.
Divide 320/diameter to get a good cutting speed. Use a drill press and oil for best result.
I smoked a Milwauke holeshooter drill before I learned the above. Then, it cut like butter!
Old Aug 17, 2004 | 09:59 PM
71coupe's Avatar
71coupe
The harder the metal, the slower the speed. You will be doing ok if you are getting a nice continous bur/chip. If the bit starts squelling you are going too fast.
Old Aug 18, 2004 | 11:03 AM
mooneyd's Avatar
mooneyd
Stainless steel is not a hard steel, unless its a 400 series. Regular drill bits (sharp) with a cutting oil work just fine. People think Stainless Steel is stronger than carbon steel but it's not, unless you go into the 400 series witch has carbon in it & will also rust. Most S/S is 300 series. Buy the way, using carbon steel bits can leave small particals in the Stainless and cause rust spots latter on. Sorry about ranting on!
Gordonm has the right idea.
Old Aug 18, 2004 | 12:50 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I agree with Cobalt bits they will go thru anything like buttter
Old Aug 18, 2004 | 12:59 PM
munday's Avatar
munday
used to have to drill it in the Navy. with your drill you want to go a little bit slow and alternate the speed up and down other wise you will not got through very easily.
To Drilling thru stainless steel....
