Sandblasting original intake
Old Aug 17, 2004 | 10:57 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Sandblasting original intake
Guys I'm split between 2 jobs, one the torquer2 to performer swap this weekend and the long term back to stock job. I have the 68 intake on the garage floor and used this paint remover that did a great job of bleaching my garage floor and blisters on my ankles from the spray lifted by the wind but still have old paint on the intake, actually 2-3 coats of Chevy orange. I'm about ready to say F&%$ it and pay to have someone sandblast it. Noticed some corrosion on the water side and wonder if I purposely leave the holes uncovered and allow them to blast sand in the water/ fuel ports can I safely assume I can remove any sand residue with several shot of air from a HP air tool or am I setting myself up for disaster?
Also the old manifold mounted oil filler is pretty beat up. Probably better to get one of the new chrome ones. Always liked that nolstalgic look. Anybody know of someone cheaper than CC?
Old Aug 17, 2004 | 11:03 PM
PRESSURERAT's Avatar
PRESSURERAT
After you get it sandblasted wash it with some hot soapy water and use a hose nozzle to rinse it out/off with. You'll be just fine. One more option is to take it to a machine shop and get it hot tanked. Good luck on your project!
Old Aug 17, 2004 | 11:07 PM
Cali,68,L-79
I'm afraid to ask what a hot tank would cost.
Old Aug 17, 2004 | 11:09 PM
PRESSURERAT
A dip in the old hot tank will probably cost about $25 bucks tops.
Old Aug 17, 2004 | 11:34 PM
Cali,68,L-79
A lot cheaper than i thought.
Old Aug 17, 2004 | 11:38 PM
The Dude's Avatar
The Dude
Problem with the hot tanks in Kalifornia these days is they can no longer use the good, caustic chemicals. Unless, of course, you really look around and find a big commercial place. Most smaller machine shops' hot tanks these days around here aren't much more than big dishwashers.
billlambeer's Avatar
billlambeer
i got a siphon feed sanblaster for about 20 bucks from home depot..works great if your gonna stick with sandblasting..maybe consider doing it yourself..
Old Aug 17, 2004 | 11:48 PM
Cali,68,L-79
Yeah but then I need a compressor and blah blah blah. I already have too many tools i'll never use again. plus I need room for all the intakes I bought that don't work the way I wanted.
Old Aug 18, 2004 | 08:24 AM
70BBvert's Avatar
70BBvert
Most machine shops will have a blasting cabinate as well. Shouldn't be more than $50 to have it hat tanked & blasted clean. Use glass bead & it will look brand new.
I use aluminum oxide on cast parts only if they are very rusty, and then follow up with glass bead. Parts come out looking like new.
Jim
Old Aug 18, 2004 | 08:54 AM
GaryS's Avatar
GaryS
I would not sandblast my intake without having it hot tanked first. I just don't think that you can get all of the sand out. And I do NOT want sand floating around in my engine. JMHO.
Gary
Old Aug 18, 2004 | 09:00 AM
Steve's74's Avatar
Steve's74
I recently had my LS-4 cylinder heads and intake manifold hot tanked at a machine shop to clean them up and it ran about $45 for all. The hot tanking did not strip off all of the paint, so I had them media blast (glass bead) the intake in their cabinet. The cost was an additional $20. They also steam cleaned the intake again afterwards to thoroughly remove any residue. Glass beading is the way to go. It stipped all of the rust, paint, oil and other residue so clean that the intake began rusting again within the hour here in our high humidity part of the country. I stongly encourage it if you want a spotless intake prior to painting.
Steve
Old Aug 18, 2004 | 10:09 AM
Cali,68,L-79
Steve
Sounds the way to go.
Old Aug 18, 2004 | 11:18 AM
norvalwilhelm's Avatar
norvalwilhelm
I don't hesitate to glass bead. It will remove everything without hot tanking. I do remove the heat shield on the underside of the intake if it has one. After bead blasting I reload the machine with new #6 glass shot and redo for a new like finish. New glass beads bring up a shine that you can not get with old dirty beads.
I thorough clean the intake after and use compressed air in every hole, corner, everywhere until I am convinced of no trapped particles.
You blast the inside as well as the outside. Do not mask anything.
Old Aug 18, 2004 | 12:10 PM
Cali,68,L-79
Thanks guys. I'm off to find a shop.
Old Aug 18, 2004 | 12:36 PM
PureSilver's Avatar
PureSilver
Sandblasting (or bead blasting- works a little smoother on aluminum...) won't affect the engine internals if you clean it by the methods listed above. Blocks are sand-cast, and they manage to get that stuff and metal filings out, so you should be OK with the intake.
I found that blasting is rather therapeutic as you see lots of progress in a short amount of time.
Old Aug 18, 2004 | 07:47 PM
Super Stock's Avatar
Super Stock
I have a 25 yr. old Holley street dominator that I did some work on the runners and plenum and port matched . I then did what Norval was saying and bead blasted it inside and out. I was going to shoot it with clear but I liked the dull alm. finish so much I left it that way. It still looks good after a couple of years.
To Sandblasting original intake
