Radiator filter???
Old Aug 18, 2004 | 02:54 PM
CGGorman's Avatar
CGGorman
Default Radiator filter???
I've got a concern about my new DeWitt radiator...
Have an engine that was broken-in on tap water years ago. It was drained, but sat forever and has a lot scale and rust in it now. I blew out what I could, but I'm still concerned that I'll block a passage in the radiator.
Are my concerns warranted?
What's a good fix? A filter?
Any ideas are welcome, but I don't have another radiator to use as a "break-in" unit.
Old Aug 18, 2004 | 03:11 PM
markdtn's Avatar
markdtn
You need a good internal flush. It needs to be hot to do the most good. No easy way to do both except in a car or a Dyno stand. You could try using a garden mixer on a hose with flushing agent in it with the hottest water you can tap into. Does not sound fun. Big trucks use a water filter, but it is a bypass type filter with a 3/8" hose.
Old Aug 18, 2004 | 03:49 PM
CGGorman's Avatar
CGGorman
I considered circulating a vinegar mix on the dyno w/o a radiator; just a standpipe...
Old Aug 18, 2004 | 03:53 PM
baja216's Avatar
baja216
I think the GM dealers have a "heavy duty" prestone radiator flush you might be interested in. It's a two part system, you put the first powder in and run on a warm engine for about twenty minutes and then you drain the system. After refilling you put the second powder in to neutralize the system. AFter that you drain and flush.
You might want to try that.
Old Aug 18, 2004 | 03:54 PM
PRESSURERAT's Avatar
PRESSURERAT
Isn't that douche?
GaryS's Avatar
GaryS
Why not disconnect your lower radiator hose and run a hose directly into it. Start your car and then just run straight tap water through it for 30 minutes or so? That way any stuff left in the engine should be washed out. Shut of the engine, let the water continue to flow for a few minutes and then drain and fill with the proper mixture.
Besides, who makes a radiator filter or even heard of one?
Gary
Old Aug 18, 2004 | 04:02 PM
Fevre's Avatar
Fevre
Originally Posted by PRESSURERAT
Isn't that douche?
To Radiator filter???
