Steering column question...
Old Aug 19, 2004 | 08:14 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Default Steering column question...
I have a tilt/telescope column (1980). Recently I was doing some blinker work and had a heck of a time reinstalling.
The reason was that the steering shaft that telescopes would come completely out when I removed the “C” clip that holds all the guts in, so even the tool that normally attaches to the steering shaft to squeeze all of it together didn’t work because the shaft would just come out.
That’s my question for today – is it normal that the shaft comes completely out when the first “C” clip is removed? If so, I need to get a different tool when I go back in..
Thanks in advance..
Old Aug 19, 2004 | 08:28 AM
Jim Shea's Avatar
Jim Shea
That C-clip is considered a critical safety item because (just as you remarked) the steering shaft AND STEERING WHEEL can come right off in your hands if the clip becomes disengaged. That is why one of the functions of the plastic C-ring retainer is to prevent the clip from working its way out of the grooves in the locking plate and the steering shaft. (BTW, the C-ring retainer also performs another function - it isolates the big telescope spring from grounding the horn contacts - i.e. your horn will blow all the time if the spring touches any metal column parts.)
What you need to do is reinstall the star screw or install a 5/16-18UNC set screw to lock the upper steering shaft from telescoping while you use the bridge tool to compress the locking plate.
There are a number of tips on working on the T&T column at the www.corvettefaq.com websight in the steering section. The first disassembly and repair paper covers the removal of the steering wheel and basic procedures to replace the lock cylinder and other minor column repairs.
Old Aug 19, 2004 | 08:32 AM
Avette4me's Avatar
Avette4me
Thanks Jim....sincerely appreciate it...
Old Aug 19, 2004 | 08:51 AM
Avette4me's Avatar
Avette4me
After a quick scan of your paper, I had to post just to say kudos to you Jim...looks like you spent a lot of time and did a superior detailed job that will surely help many of us...myself for certain...
Old Aug 19, 2004 | 11:45 AM
vettfixr's Avatar
vettfixr
Lonnie, you know you shouldn't be messin' with 'chinery.
Old Aug 19, 2004 | 12:02 PM
Avette4me's Avatar
Avette4me
I'd whoop ya for that 'cept I just know you'll hit me with ya cane....
Old Aug 19, 2004 | 12:33 PM
wcsinx's Avatar
wcsinx
Jim is to steering what Lars is to carbs & ignition. His writeups helped me immensely when I tore down my column.
A note on that big arsed spring: (if you don't have the proper compressor thingy) I reinstalled the c-clip by first taking off the driver's side T-top so I could stand up and get some leverage, then I took a big pair of channel lock pliers and wrapped a towel around the jaws, then with my right hand and stomach I compressed the locking cog with the plier's handle ends, while notching in the c-clip with my left hand. Then once I had it notched, and the lock wheel wasn't going anywhere, I tapped it home with a screwdriver.
Old Aug 19, 2004 | 12:55 PM
Avette4me's Avatar
Avette4me
I'm still pondering the star screw that Jim is referring to. I thought that it bolts into the center of the shaft right where the compression tool bolts to...I'll know more tonight when I start if I don't hear back first...
If I don't hear back from Jim, I'll be using the grunt an cuss method you're describing...
thanks
Old Aug 19, 2004 | 01:26 PM
wcsinx's Avatar
wcsinx
I don't think you should be bolting anything to that seeing as there's nothing holding it in/down.
Old Aug 19, 2004 | 02:30 PM
Avette4me's Avatar
Avette4me
You're right, but the tool is designed to pull down on the steering shaft to compress that big *** spring.... I went out in the parking lot and looked and it appears that you put the star screw back in to lock the shaft, and then the put the compression tool on the where the nut that holds the steering wheel on would normally go....if that's correct, i now understand what Jim was saying...
Old Aug 19, 2004 | 02:58 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
I did the same thing, except I sat on the top rear and used my feet to compress the cog.
Old Aug 21, 2004 | 10:13 AM
Avette4me's Avatar
Avette4me
For anyone interested in knowing, I purchased a new compression tool for $16.00 at the local auto store. It has an adapter that pushes a pin into the part that locks the telescoping shaft for a very easy reassembly..
Jim's suggestion of using a set screw works well also.
To Steering column question...
