Steering wheel
Old Aug 19, 2004 | 09:13 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Steering wheel
My telescoping wheel will not lock the car has an aftermarket grant steering wheel on it can anyone help me fix the telescoping part
Old Aug 21, 2004 | 10:18 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
You could telescope it to the desired position, then put a bolt or set screw into the center of the telescoping shaft. The bolt should be long enough to lock into place. You won't be able to adjust it at will, but could set it up so it fits you.
