196hp??? THAT'S ALL?????
Old Aug 29, 2004 | 09:50 AM
  #61
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by DJ Dep
Way too much emphasis placed on horsepower and not enough on actual performance gains. You can have LESS horsepower than someone else and still beat them in the 1/4 mile if you are able to EFFICIENTLY put the power to the road.
Dep
Old Aug 29, 2004 | 10:26 AM
  #62
Jvette73's Avatar
Jvette73
True performance is a measure of driver, car, weather, track conditions...ect. This can only be done at a dragstrip. Dyno schmyno...blah blah blah.....
As for your cam choice I can offer my direct expierence with both the 268 and the 262. I have run both these cams in my setup(listed below) with no other changes. The 262 wins hands down for me. It produced smoother idle quality, better vacuum and better 1/4 mile ET and MPH. It just matches my other components better. The 262 is definatly more comfortable at idle in gear. I would always have to bump it to neutral at a stop with the 268. To have maximized the potential benifits of the 268 I would have had to change other things such as bigger carb, better intake, higher stall, stickier tires..ect.
Old Aug 29, 2004 | 11:42 AM
  #63
Glensgages's Avatar
Glensgages
Dynos are great for getting the tune-up 'close', but the REAL THING is on the strip!
Do you wanna walk around, showing-off and bragging about a dyno print-out, or an ET-slip?
ET-slips are ALOT more fun to acquire!!!
