my corvette initiation - now i need HELP!
well 15 minutes from home i go (very gently) over some nasty railroad tracks when it happens......SNAP! followed by the worst grinding noise my ears have ever heard. ugh.
i guess this is my initiation into C-3 ownership.
well, the bolt/tie road/whatever holds the left-most side of the leaf spring had busted clean in half. the spring was dragging, the leafs have slightly separated - party! heh....try tow truck. so. now i have some questions:
1. i suppose a new spring is in order (as the leafs appear separated): it sounds like composite is the way to go. any suggestions? is composite the correct choice? best place to purchase? (hi vendors!)
2. how do i get this spring off (besides going back to the tracks). do i start on the (remaining) end, or do i start with the middle? how do you safely unload the spring to get it off? (support with a jack im guessing?)
3. some of you may have read my post on a leaky rear end. i suppose this is a great opportunity to fix that. ive seen some posts on a "heavy duty" rear end cover. since i would most likely break the stock cover (which appears to be the problem with these cars) when installing a new spring, should i just go ahead and snag one of these?
sorry about the novel fellas (and ladies). i knew i'd have to do some work eventually.....i just wanted to drive her for a while first. i appreciate the help!
Check out Corvettefaq.com for most of the answers you are after. If your old cover is OK then keep using it. Mine is 34 years old and no cracks in mine. If you pull the rear end then you should get it at least looked at (maybe rebuilt) while it is out. It is all about time and money. Do you have the time and money to rebuild it right now? If not just do the spring and leave the rear end till winter.
Use a pair of vice grips to clamp to the sping and put a floor jack under the other end and lift the spring up until tension is off the spring-T-arm bolt. If it is seized up just cut it and buy new ones when you get a new spring. DONT cut or loosen the bolt under tension. You must support the spring while you remove those bolts.
Van Steel and VBP have the spring kits.
One last thing - don't tighten the spring to full torque ratings (ie bolts to diff) until the car is on the ground and weight is on the srping. That is one of the main reason the covers crack. People torque the rear end bolts with the car in air. It puts stress on the covers after the car weight is applied (as the spring is flattened out and pulls the rear end ears out).
Take some time to learn about your car, you will work on it as long as you own it so don't loose your patience.
Good Luck,
Gary
Good Luck,
Gary
it doesnt appear that the dif. cover is cracked.....when i've been searching the archives it appears that a lot of people crack them as they install new springs (which i obviously need to do) - i figured mine would crack as well, just because that is my luck - and thanks for the tips Stingry. i need to take the cover off anyway as it appears the gasket is kaput. anyway...just wanted to clarify that detail.
Now, given that you just got the car and have already broken a bolt, I would suggest that since the car is out of commission anyway, now would be the time to drop the rear, remove the trailing arms, send them out have them rebuilt, replace the bushings on the strut rods, etc... You will be glad you did. This stuff will have to be done soon if it hasn't been done, and it will save you both money and time to do it all at once. Not cheap, but it is a onetime thing and you are done. In the meantime, you can go through the rest of the car.
BTW- have you checked the brake calipers? While you have them off to do the trailing arms..... Welcome to Vette ownership!
