Hood flew off at 80 mph!!!
Old Aug 22, 2004 | 07:28 PM
Vetter Atl's Avatar
Vetter Atl
Default Hood flew off at 80 mph!!!
After I autocrossed today, while driving home, my hood flew up at about 80! I almost lost her into a gaurdrail (I couldn't see)! The only thing that held it on was the prop rod and the locks by the widshield! Anyway, the front bolts on both sides pulled throught the fiberglass with the reinfocement plates still attached! On closer investigation, it looks like bubba had tried to "fix" it before. So, I need someone who can do good bodywork in the Atlanta area. Do you guys know of someone who is good and fair about the price? Thanks.
Old Aug 22, 2004 | 07:31 PM
Stoge's Avatar
Stoge
I'm not sure I wouldn't just order a new hood and hinges instead of having yours fixed. If bubba got ahold of it once, I bet its gonna take a good bit of work to get it fixed properly.
Old Aug 22, 2004 | 07:39 PM
norvalwilhelm's Avatar
norvalwilhelm
The nice thing about fiberglas is you can grind it out and refill it to as strong or stronger then before. With heavy enough cloth the area can be greatly reinforced.
Old Aug 22, 2004 | 07:45 PM
Vetter Atl's Avatar
Vetter Atl
yeah, iwant to to do it right and while it is there have some other body stuff taken care of.
Old Aug 22, 2004 | 09:07 PM
PRNDL's Avatar
PRNDL
holy cripe!! And here I always thought with our hoods opening from the back it couldnt fly open and block the view!
Old Aug 24, 2004 | 11:17 AM
Vetter Atl's Avatar
Vetter Atl
Yeah, I think the hood was a little up off the nose (bad body work) and air was getting under it. Any Atlanta guys know of a good shop?
Old Aug 24, 2004 | 11:35 AM
Twin_Turbo's Avatar
Twin_Turbo
Yup, and if you use a layer of woven cloth & epoxy resins it will be really strong, then you can finish off with some polyester resin and some matte for smooth transition into the original parts.
Old Aug 24, 2004 | 11:39 AM
gkull's Avatar
gkull
That's strange, because the hood shouldn't catch air on a Vette. I've driven with my hood not locked down so I could see under hood oil and fuel pressure gauges while I was driving.
Old Aug 24, 2004 | 11:43 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
It can if the front bolts fail and the front edge is higher than the front body work. This sounds like it's what happened here.
Old Aug 24, 2004 | 11:53 AM
gkull's Avatar
gkull
I failed to read exactly what went on. I'd be tempted to just buy an aftermarket hood. My TT hood only needed to be painted. My hood got stolen when I had it at a shop for a paint job.
Old Aug 24, 2004 | 12:10 PM
markdtn's Avatar
markdtn
Call John at 770-461-5211. They will be on the way to Carlisle later today.
Old Aug 24, 2004 | 12:38 PM
nastee383's Avatar
nastee383
Don't you hate when that happens???
Old Aug 24, 2004 | 12:56 PM
Corvus's Avatar
Corvus
Ya there's no way theh ood was aligend with the nose, if it was it would be like impossible for it to rise, the air pushes our hoods down
Old Aug 24, 2004 | 01:45 PM
mrvette's Avatar
mrvette
Did it break at the hood or the hinges come off the car fender linders....there is a metal bracket on mid years that goes from either hood mounting point, and then down either side of the radiator support, catching all the bolts in the sides....
GENE
Old Aug 24, 2004 | 03:02 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Bet that was exciting. How long did it take you to clean your britches out?
Old Aug 24, 2004 | 08:09 PM
GaryS's Avatar
GaryS
I am confused. How does a hood, that mounts at the forward part of the car, fly up? Were you driving backwards while going home?
Gary
Old Aug 24, 2004 | 09:14 PM
Burnt71's Avatar
Burnt71
A few years ago I had my 71 painted, did most of the work myself after hours, a a local body shop, I had the car almost reassembled ,exept for the hood and doors, I wanted to see how it would look with the hood on so we laid the hood on the car, It looked good , It was late so we decided to leave the hood on the car since it was a safe place to store it. The next day the body shop owners son decided to move it. He drove it to a small warehouse about 3 miles down the road . So I guess I was lucky the hood never came off . It went 3 miles at highway speeds with no hardware to hold it down.
To Hood flew off at 80 mph!!!
Old Aug 24, 2004 | 09:23 PM
lowvette's Avatar
lowvette
Just a couple of guesses...
1. Hitting the brakes hard and letting momentum do the work.
2. Rounding a corner the hood slides off to one side and the wind picks it up from there.
Old Aug 25, 2004 | 03:56 AM
GaryS's Avatar
GaryS
Those hoods are heavy. I can't buy that scenario.
Gary
Old Aug 25, 2004 | 04:22 AM
WESCH's Avatar
WESCH
Hi
Aerodynamics are strange. Think about a wing from an aircraft. It's curved on top and flat on the bottom.
The aircraft flies not because the underside of the wing pushes it up, but because the curved upper side of the wing pulls ( sucks ) it up.
This is caused by the air requiring to travel a longer distance over the curved top surface than over the flat lower surface, hence raising speed therefore reducing the pressure and sucking the wing up.
The hood of the Vette might react similar. Remember that road contact of cars reduces with higher speeds.
Rgds. Gunther
