Radiator auxilliary fans
Old Aug 24, 2004 | 11:03 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Radiator auxilliary fans
What is the best way to mount auxillary cooling fans - pushing or pulling air thru the radiator? The guy I bought my BB from had the 2 electric fans pulling air (engine side of radiator) thru the radiator. I have the car apart and want to put it back together to cool the best. My logic is to push air through??
Old Aug 24, 2004 | 11:30 AM
Fevre's Avatar
Fevre
Pullers are more efficient than pushers.
Old Aug 24, 2004 | 11:45 AM
L88-68's Avatar
L88-68
6th Gear
I agree pullers are much better.
Old Aug 24, 2004 | 12:16 PM
markdtn's Avatar
markdtn
Use a puller fan.
http://www.idavette.net/hib/bbfh7.htm tells of one way to do it.
Old Aug 25, 2004 | 08:41 AM
Hvymtlc5's Avatar
Hvymtlc5
Can anyone explain why. To me it seems like pusher fans would be trying to impede (pushing against) air coming into the radiator?
Old Aug 25, 2004 | 09:17 AM
checklst's Avatar
checklst
Most (I believe) are referring to a puller mounted on the engine side of the radiator. If you mounted a pusher on the engine side (you are right) it would be impended as it would be pushing against the normal air flow.
A pusher fan on the front side (head light side) of the radiator would be just as efficient as a puller but their is a space issue with the hood in the open position their not enough room on the upper half of the radiator for a fan.
Old Aug 25, 2004 | 09:27 AM
Hvymtlc5's Avatar
Hvymtlc5
Good point. The flex-a-lite fans are reversable. I had the hood off while everything was coming out and didn't notice that there may be a clearance problem if the fans were mounted on the "outside" of the radiator (logical place to put them in my thinking).
Old Aug 25, 2004 | 10:39 AM
stingr69's Avatar
stingr69
The General likes "puller" fans. I have both the engine mounted factory "puller" one and the factory auxiliary electric "puller" fan on my '80 L-82.
I "think" pulling is more efficient from a fan performance issue. Probably has something to do with the open area behind the fan creating a low pressure area vs high static pressure from blowing directly at a radiator. I used to design HVAC equipment so I realy should know this. I bet it is something like that.
-Mark.
To Radiator auxilliary fans
