Rear Main???
Old Aug 24, 2004 | 10:46 PM
Corvettelvr73's Avatar
Corvettelvr73
Default Rear Main???
Does the transmission have to come out to change a 2 piece rear main seal??
Old Aug 24, 2004 | 10:52 PM
Gordonm's Avatar
Gordonm
No. You can drop the pan without removing the trans. Lower the steering shaft by undoing the idler arm. This will give you enough room to get the pan out. Remove the pump then the rear cap and you have access to the rear seal.
Old Aug 24, 2004 | 10:57 PM
moosie982's Avatar
moosie982
Hi, No, but room is scarce. Peace,,,Craig
To Rear Main???
