Vacuum relay valves leaking. Normal? Rebuildable?
Old Aug 26, 2004 | 11:42 AM
CGGorman's Avatar
CGGorman
Default Vacuum relay valves leaking. Normal? Rebuildable?
Hooked a vac pump to the wiper/headlight system this morning and found both relay valves to be leaking past the "piston". The diaphragms are OK. Is this leak normal? I'm assuming not... Can they be rebuilt? I didn't have enough time before leaving for work to study them. Besides, after finding the leaks I figured I'd just buy replacements . Replacements are like $60 ea, though. I'll spend the money if I have too, but it's too much to simply accept if there is a possibility of a rebuild.
Old Aug 26, 2004 | 12:38 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I did the same test on mine a few years ago. Leaking is not normal. I used to have a link to someones site that detailed a repair of the piston. It involved using RTV. I think the last time I tried visiting the site it was down. I usually repair things like this as well but I didn't feel like messing with it. So I just bought new ones and now my headlights really work great.
Old Aug 26, 2004 | 01:32 PM
wcsinx's Avatar
wcsinx
Here's the write up from my repair.
1. Carefully disassemble the relay by prying up the retaining ring all the way around.
2. Pull the plunger/bladder assembly out of the plastic port housing.
3. Get two little o-rings and put them around either end of the rubber "dumbell" shaped diverter that's at the end of the shaft attached to the bladder. It might take a few tries with different sizes, but get ones that offer just the tiniest bit of resistance with the port housing once "installed" on the rubber diverter.
4. Get a cotton swab, impregnate it with grease, and then use it to put a thin film of grease inside the port housing.
5. put a thin coat of RTV on the outer end of the diverter and slide it carefully into the port housing and let it set overnight
6. remove diverter from port housing and repeat steps 4 & 5 for the inner end of the diverter (you'll have to slide past the outer end this time, that's why we let it set up first)
7. pull diverter back out, regrease a little, reassemble
Note: You might be able to skip the RTV-ing part altogether if you feel you got a sufficient seal with just the o-ring and grease. I did not however, and the RTV got me damn near airtight. I'm going on 2 years with this repair.
Old Aug 26, 2004 | 01:35 PM
CGGorman's Avatar
CGGorman
Good stuff. Thanks for the tip! I'll try it tonght!
Old Aug 26, 2004 | 03:10 PM
markdtn's Avatar
markdtn
There used to be a rebuild proceedure with some photos on the corvettefaq site. Don't know if it is still there or not.
Old Aug 26, 2004 | 06:28 PM
goinbroke's Avatar
goinbroke
Here is a site with some pics.....once there click "headlight relay repair".
http://iotech.no/corvette/
You don't need to do all the steps in the procedure shown, but pics can be useful. I did almost exactly the same rebuild as the write-up in the above post. I believe the o-rings I used were 5/16" OD X 3/16" ID X 1/16" thick. The idea is to flare the cups at each end of the rubber piston with the o-rings. Stick them there with RTV or 3M weatherstrip adhesive. Mine have held for 2 years now.
Old Aug 31, 2004 | 09:44 AM
CGGorman's Avatar
CGGorman
Thanks for the help, guys! I fixed both my relays at a cost of $0.76. I couldn't be happier! I blasted them and painted them prior to reassembly. I used a specialized vacuum grease to seal up the diaphragm and o-rings. We use lot's of vacuum equipment here at work, so I borrowed a little. Anyway, they now hold a 25+ vacuum with no leakdown.
One question...
Jus how fast os the wiper door supposed to close? Mine is almost violent with the force it uses to pull closed. Perhaps, I just applied too much vacuum?
Old Aug 31, 2004 | 10:09 AM
wcsinx's Avatar
wcsinx
Vacuum grease? That sounds promising. Where would get ahold of "vacuum grease".
I think I seem to recall people mentioning some sort of pressure limiter for the wiper door. I can't find any part like that though, so I'm just going crazy again. You could fab one yourself though if you think the door is slamming closed too fast. Just patch in a piece of smaller line. But you're probably fine regardless. With a leak free system, the lights and wiper door can snap open and closed pretty quick.
Old Aug 31, 2004 | 06:44 PM
Wife'sVette's Avatar
Wife'sVette
Default wonderful
glad you got them fixed, vacuum grease does sound good though ...... hmmm....... any I used this site referred to thruogh this forum ... here look to the left and there is a vacuum troubleshooting section ....... a quick ???? , I used brake fluid to enlarge my piston was that wrong? it works now though . Robert
Old Sep 1, 2004 | 06:57 AM
Tom454's Avatar
Tom454
I use this stuff... Dow Corning High Vacuum Grease-
"A Silicone Lubricant For Glass Stopcocks, Joints, And Glass-Rubber Connections. Resists Most Chemicals, Heat Stable, Inert."
Scientific supply houses carry it. Probably any silicone based grease will do though... easy to find stuff..... Radio Shack... for CPU mounting (heat sink grease) I believe is silicone based.
You're not supposed to use any petroleum based products on the relays because petroleum will mess up the plastic & rubber parts.
Old Sep 1, 2004 | 07:26 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
What about dielectric grease. Is that a silicone type grease?
Old Sep 1, 2004 | 09:56 AM
Wrencher's Avatar
Wrencher
Mine opens and closes very quickly. Wish I'd seem the repair ideas when I repaired my vacuum system a couple of years ago! Luckily I save everything, so I'll try the repairs on my two original relays. If you haven't already done so, replace the filter! Most of the problems associated with the system are moisture and dirt related.
Hans
Old Sep 1, 2004 | 01:58 PM
Tom454's Avatar
Tom454
One form of grease... don't know if this particular one is good for the relays though... dielectric type...
http://products3.3m.com/catalog/us/e...er/output_html
Old Oct 20, 2011 | 07:49 PM
mandingo214's Avatar
mandingo214
To update this post, I just rebuilt my vacuum relays, using 11/32 O-rings.
Tips I found useful:
1)I bought the cheap vacuum pump from Harbor Freight, as it is hard to hear vacuum leaks when the engine running, and I do not like the idea of pulling vacuum from another car parked outside.
2) Rubber restore was not available, and soaking the pistons in brake fluid for 24 hours did not work for me.
3) Putting the O-ring "inside" the piston end, then holding it in place with a washer worked (see bottom end of piston in picture), but it takes up too much space to do both ends.
4) Cutting a groove in the piston where there already is a bit of a groove, and rolling the O-ring into it, worked great (see top of piston in picture), and it is easy to do both ends. This is what I finally decided on, and the valves work great. I used Vaseline to grease the bores.
5) I used a mig-welder to put the retaining ring back in place, but the suggestion of using a hose clamp is probably better.
Hope this helps.
To Vacuum relay valves leaking. Normal? Rebuildable?
