Motor ????
Old Aug 26, 2004 | 02:03 PM
BAD 99's Avatar
BAD 99
Default Motor ????
1 intake that clears the stock hood
2 what heads are you running
3 Cam? last cam was a Comp Cam 268 , that car was an Auto .
so i was thinking a little bigger on that , the 71 is a 4 speed
thank for your help
Old Aug 26, 2004 | 03:39 PM
comp's Avatar
comp
ah, need more info on what you want
Old Aug 26, 2004 | 03:46 PM
GaryS's Avatar
GaryS
Confused as to what you are asking?
Old Aug 26, 2004 | 03:59 PM
Gordonm's Avatar
Gordonm
More info needed
Old Aug 26, 2004 | 04:01 PM
olouieo's Avatar
olouieo
Old Aug 26, 2004 | 04:05 PM
BAD 99's Avatar
BAD 99
To sound like an old vette , and to drive it every day ,if i like
this is what i am thinking for a new motor
the bock is getting 30 over flat top piston
iron eagle [dart] head 202 or aluminum
comp cam 272 ,with a dual plane intake demon carb , would like to know if the hood will close .
and if anybody has something like it
Old Aug 26, 2004 | 04:27 PM
marshrat99's Avatar
marshrat99
My 79 has about what you're describing: 30 over flat tops, Dart Iron Eagle 180's, CompCam XE262, Edelbrock Performer EPS Intake and Holley 670 Street Avenger. I topped off the carb with a 3"x14" drop base, offset air clearner. It is tight but just does clear the hood.
Old Aug 26, 2004 | 05:04 PM
BAD 99's Avatar
BAD 99
thanks does you cam have any lope to it ? or does it sound like a stock cam
Old Aug 26, 2004 | 07:55 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had a similar 355ci motor Sportsman II heads, RPM Air Gap intake CC 282 solid cam, 10:1 Cr Holley 750 DP made 296RWHP and 327RWT
Old Aug 27, 2004 | 02:35 AM
71coupe's Avatar
71coupe
If you are really looking for that sound, Comp cams has their Nostalgia plus line
http://www.compcams.com/Technical/Cu...ML/128-169.asp
The 30-30 might be too rough, but the N+L79 would work. Adding chambered exhaust would complete the "sound"
http://www.ecklers.com/product.asp?p...EF4W2NU8K660A1
Or you could install stock style mufflers for a quieter sound.
If you are in the market for heads, go with aluminum (AFR, Dart, Brodix)
Keep the intake volume around 200cc or less and combustion chambers at 64cc (You will have a decent compression ratio with flat tops)
I have the low flat hood on my '71. With the orig air cleaner & q-jet & an Edelbrock Performer 2101 intake - the hood slightly touches the front of the air cleaner.
You may lose a little hp with the old school cam, but it will sound good
Old Aug 27, 2004 | 03:40 PM
marshrat99's Avatar
marshrat99
Thanks to 9.7:1CR and MAD chambered exhaust, my 79 has a noticable but not huge lope at idle.
To Motor ????
