M-21 Shifter linkage adjustment...
Old Aug 27, 2004 | 06:46 AM
nhlgopens's Avatar
nhlgopens
Default M-21 Shifter linkage adjustment...
I was wondering if anyone has ever re-adjusted their shifter linkage to the second holes on the gear levers (closest to the pivot point)? I recently purchased a new linkage kit <30 years of abuse> and thought I would try the other holes. It shortens the shift throw by about 50%. Am I safe in trying this - or is it going to cause problems? BTW - I ordered the linkage kit from one of the supporting venders and was NOT impressed with it. The new levers had to have the slots filed longer by over 1/8 of an inch, the original slots have rounded areas in the middle for the bolts to pass through - these didn't = more filing, and my M-21 has factory bolts (as stated above) this kit came with nuts... WTF? I suppose some M-21's have studs on the trans to which the kit should be supplied with both. The kit was also missing a cotter pin. Fortunately I had one, of course it's probably not NCRS
Old Aug 27, 2004 | 08:54 AM
stingr69's Avatar
stingr69
The Muncies for 68 and older use nuts and studs on the tranny levers. The 69 and up use bolts to retain the levers. It sounds to me that you have the wrong linkage for the tranny.
-Mark.
Old Aug 27, 2004 | 09:10 AM
nhlgopens's Avatar
nhlgopens
-Mark.
That's possibly what I thought... but the paper in the kit - wrapped around the parts stated 74-76 M-21.
From vender's site:
74-76 SHIFTER LINKAGE KT
Code: SH011A
Price:$69.00
Shipping Weight: 2.68 pounds
That's the part # on the bag and paper. If I got the wrong kit, they put the wrong parts in the right bag with the right papers... all of the linkage rods were correct length - just the levers needed some work.
I don't want to sound like a negative add to the supporting vender because I was able to work with what I got... my main question was for using the other linkage holes. I like the shorter throw - hopefully it won't cause me issues.
Old Aug 27, 2004 | 11:45 AM
Schmucker's Avatar
Schmucker
Didn't the '74-'76 use the T10 and not a Muncie?
Old Aug 27, 2004 | 12:00 PM
nhlgopens's Avatar
nhlgopens
Nope... M21 (Close ratio 4-speed) and M40 (Turbo Hydromatic) were the trans options. 3,494 built with M21 - 25,146 built with M40 for '74. '79 went to the MM4 manual... I haven't seen any T10 info for the C3's.
Old Aug 27, 2004 | 12:01 PM
stingr69's Avatar
stingr69
Muncies were gone in 75 but you could get the Warner tranny or the Muncie in 74 I think. Which tranny do you have? It might not be original.
Keep in mind that M-20 does not always mean Muncie.
-Mark.
Old Aug 27, 2004 | 12:07 PM
nhlgopens's Avatar
nhlgopens
-Mark.
I definitely have the M21 - matching numbers car...
Old Aug 27, 2004 | 12:10 PM
glen242's Avatar
glen242
I used the lower holes on my '76 T-10 before I went to a Hurst. No problems. Try it, you'll like it.
Old Aug 27, 2004 | 01:03 PM
crazydalys's Avatar
crazydalys
Default Tranny
According to L-82.com, my 76 has the M-21 close ratio. Is that incorrect?
Old Aug 27, 2004 | 01:52 PM
nhlgopens's Avatar
nhlgopens
I don't know - but it's making quite a discussion... The site I used had the M21 option listed up to 1978 to which it was changed to the MM4. Previous to 74 there were options for M20 and M22. Roger's Corvette has good info and history. If you click the link associated to years, it gives options, interior/exterior colors with quantities of each option sold. I can't validate the accuracy, but it seems to be a good pointed resource.
Old Aug 27, 2004 | 03:16 PM
stingr69's Avatar
stingr69
M21 was not always "Muncie", It just meant "close ratio 4 speed". The supplier was Warner in the later years. M-20 is a code for "wide ratio 4 speed", not a specific tranny. M-22 was "close ratio extra heavy duty" that was the "Rock Crusher" but if you had that option, it was always Muncie. This option was not available any other way.
For example: '69 M-21 was "Muncie - close ratio" while '76 M-21 was "Warner - close ratio".
If you bought a 69 Camaro with the base V-8 and an M-20, you got a "Saginaw - wide ratio" tranny. If you had a 69 SS-396 Camaro and ordered M-20, you got the "Muncie - wide ratio". Just a code, not a specific tranny.
74 Vettes used both Muncie and Warner but they were Warner after that.
-Mark.
Old Aug 27, 2004 | 05:46 PM
crazydalys's Avatar
crazydalys
Default Thanks
Thanks for the info!!
Old Aug 27, 2004 | 06:53 PM
joe73vette's Avatar
joe73vette
in answer to your original question, yes go to the inner holes. it'll feel much better and do no harm. joe
Old Aug 27, 2004 | 08:32 PM
stingr69's Avatar
stingr69
Yes, that and the 70-73 linkage would probably fit better. I figure you got Warner parts going on a Muncie tranny.
-Mark.
To M-21 Shifter linkage adjustment...
