I've ordered an Edelbrock 600cfm carb to replace my Q-jet.
What type of adapter will I need to fit the Edelbrock square bore on to my 79 L82 spread bore manifold,can it be an open plenum,or should it have the 4 holes to match the carb?
Thanks Neil.
Did you order the 1400? Just put one on my 78 and it came with the adapter.
Thanks everone for the replies,it's a 1405.I prefer the manual choke,that way I know that it's off,also has slightly richer jetting.
I will go ahead & order the 4 hole adapter,
