Stock stall speed....?
Old Aug 27, 2004 | 09:14 AM
1970-Bronze's Avatar
1970-Bronze
Default Stock stall speed....?
Anyone know what the stock stall speed for a 70 Corvette?
So, any ideas what a B&M 2000 would stall in a 70' with a 383' with about 420 hp / 480+ Tq?
Old Aug 27, 2004 | 11:43 AM
Schmucker's Avatar
Schmucker
About 1500. Put your foot on the brake and apply throttle and see when it starts to want to pull forward. Call a transmission place and have them match up a converter for what you want. Torque changes converter stall speed. So a converter might stall 2000rpm with 300ft-lbs, but do 3500rpm with 500ft-lbs. Just a random example. Normally the converter is matched to your cam. They'll want a list of things about your setup though.
Old Aug 27, 2004 | 12:07 PM
1970-Bronze
Understood.
Have any idea what the B&M is rated at? (Meaning a 3500lb car that makes 400 tq)
I was really trying to see if anyone else had any experience with this.
Old Aug 27, 2004 | 12:32 PM
marshrat99's Avatar
marshrat99
[QUOTE=1970-Bronze]Have any idea what the B&M is rated at? (Meaning a 3500lb car that makes 400 tq)
QUOTE]
B&M can be orderd with different ranges. The "stated" torque for my XE262 cam is 415lbs and I'm running a 2500 RPM stall. Summit helped on this selection given my engine, cam, weight and tire size. Me thinks the stock converter would have been just fine with my engine setup.
To Stock stall speed....?
