Inserts for headlight holes
Old Aug 28, 2004 | 09:47 PM
81VetteFreak's Avatar
81VetteFreak
Default Inserts for headlight holes
Do they make body panel inserts to fill in the holes where the headlights come up ?
( Ones that you glass in )
Thinking of mounting small headlights down where the running lights / turn signals go .
Old Aug 29, 2004 | 06:11 AM
81VetteFreak
Anxiously wanting to know ........
Old Aug 29, 2004 | 06:18 AM
81VetteFreak
Does anyone out there know ?
Old Aug 29, 2004 | 06:21 AM
Twin_Turbo's Avatar
Twin_Turbo
No. To get the proper contour it wil be easiest to laminate a mold on top of some existing lights (out of car) and thenfrom that mold laminate an insert. The problem is that most people that cover them will use flat sections and the headlamp lids are not flat, there's a slight curve to them. I think Big632 has glassed in lights, might want to ask him how he did it.
Old Aug 29, 2004 | 07:56 AM
81VetteFreak
Thanks , I'll give him a shout .
Anyone know where I might find a pic of what it would look like ?
Old Sep 4, 2004 | 07:38 AM
81VetteFreak
Its hard to believe as long as this type of vette has been out that noone has made a mold and sold these filler panels .
Ive seen several vettes with these holes filled and the headlights mounted down low . They look awsome !
Old Sep 5, 2004 | 12:35 PM
81VetteFreak
Default Running question again
Does anyone make fiberglass filler panels to fill in the holes where the original headlights went ? Wantint to mount headlights down low where the running lights go .
1981 Corvette
Old Sep 5, 2004 | 06:13 PM
aharte's Avatar
aharte
I don't know the answer to your question, but this sounds dangerous. The lightiing is already crappy enough, and you're going to make it much worse. I'm pretty sure it's illegal too. So if your state requires an inspection, you may not pass.
Old Sep 5, 2004 | 06:23 PM
81VetteFreak
Naaawww , with the Headlights down low the lighting would be better than fixed mounted in the original holes . That is how I had them on my Manta and it was legal .
Old Sep 5, 2004 | 06:29 PM
Twin_Turbo's Avatar
Twin_Turbo
The projection on the road surface is what counts, if you have the lights mounted down low you have to angle them real shallow to get a decent projection, this also means that a large portion of the beam is aimed stright ahead and up, possibly blinding oncoming traffic. I'm not sure what the rules are over there but here there are clear rules as to the minimum height of the headlamps.
Old Sep 5, 2004 | 06:35 PM
81VetteFreak
This I understand but we are talking only 4 to 5 inches lower and there would still be a good 8 inches underneath them to the ground .
Old Sep 5, 2004 | 06:59 PM
aharte's Avatar
aharte
Take a second and draw yourself a diagram. The beams have a fixed divergence. As TT said, you'll have to aim them very shallow. When you do this, the top portion of the beam will mostly miss the road.
If the road is changing slope, then the problems are much worse. Mounting the light lower gives you a lot less leeway.
If your figure of 8 inches is correct (I'm guessing it's not), that is way too low. California and Alaska for example requires 24 inches from the center of the headlight to the ground. Canada requires 60 cm (~24"). I imagine everywhere else is similar.
Old Sep 5, 2004 | 07:08 PM
81VetteFreak
8 inches was a understatement , 15 inches is more like it . Just got through measuring it .
I dont know what the laws are here but checking it would defenitely be wise before doing this conversion .
To Inserts for headlight holes
