Starting Problems
Old Aug 28, 2004 | 09:48 PM
The76corvettekid's Avatar
The76corvettekid
1st Gear
Default Starting Problems
I have a 76 corvette. I have just started having problems starting it. The only way it will start right now is by using a screwdriver on the starter and having the key on the on position. When you try to turn the engine over with the key nothing happens. I checked the starter its fine. I replaced the ignition switch above the steering column. That didn't work. I bypassed the clutch switch and that didn't work. I am stumped at how to fix this problem. If you have any answers please reply. Thanks
Old Aug 28, 2004 | 11:27 PM
vettedan's Avatar
vettedan
If you have a meter, measure the resistance between the chassis and the battery ground. Bad grounds can do crazy things. Check and see if you have 12 Vdc at the positive ignition lead on the starting solenoid. While your checking this have someone turn the ignition switch to start. If you don't get 12 volts than either you have a bad fuse link, ignition switch or some other open or short in the ignition circuit. I've seen the distributor chrome noise shielding rub the insulation off the 12-ignition wire to the solenoid and causing a short, thus causing the fuse link to open. I hope this helps.
Dan
Old Aug 28, 2004 | 11:31 PM
RussellMc's Avatar
RussellMc
For what it's worth my '75 had the same problem for the last couple of years (I actually installed a pushbutton start switch) before deciding to replace the starter. My starter had checked out okay too; but, for something like $35 for a delco-remy from autozone it was worth a try. Now it starts great using the ignition switch so it actually was the starter.
Good luck,
Russell
Old Aug 28, 2004 | 11:47 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I was going to suggest the starter selenoid. It may not be your starter since the screwdriver bypass seems to get it going.
Old Aug 29, 2004 | 12:12 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Sounds like solenoid.
Old Aug 29, 2004 | 12:18 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default It's probaly the solenoid
From here in California it sounds like the solenoid to me. The is a disk contactor inside the solenoid cover (on the starter) that gets burnt up from all the arcing. And BTW cleaning the outside terminals is not cleaning the inside contactor. My first try would be to clean this part and so you can maybe save a few bucks:
1- mark each wire and terminal before you remove them from solenoid so you will know where to replace them.
2- remove that solenoid cover that contains the terminals you just marked (2 screws).
3- remove the spring and contactor disk - should just fall out.
4- clean or just flip copper disk over and clean the contact terminals inside cap/cover (sandpaper, alcohol, etc)
5- reassemble as marked
6- post yer results and let us know if advice was any good
Happy hunting. cardo0
To Starting Problems
