Shifty help
Old Sep 1, 2004 | 07:09 AM
wugak's Avatar
wugak
Default Shifty help
The shifting of my 77 L82 4 spd is a bit clunky. I hunt for first gear and sometimes it doesn't engage and I get a nice grind instead of motion. A mechanic I trust (weird eh?) told me it is probably the shift mechanism and not the tranny.
If I'm headed down this path then a complete shifter with all the bushings and rods is pretty short money, about $270 complete.
Questions:
1. Anyone had experience where the shifter and linkages fixed problems vs a tranny rebuild?
2. I don't care about originality and such, and I am considering the Hurst option. Its about the same $$ and seems to be well received. Any advice yay or nay?
3. Is replacing and adjusting the shifter a driveway weekend job for an ok mechanic or more complicated than it looks?
Thanks for the help
Tony
Old Sep 1, 2004 | 07:28 AM
GTR1999's Avatar
GTR1999
Tony,
The stock shifters mount to the crossmember and the Hurst comp+ mounts to the tranyy tailshaft housing. You can replace them,but from under the car. You'll have to get the exhaust out of the way and you should be able to work in the tunnel. It's a tight fit but it can be done.
The Hurst has shorter throws then the stock shifter and is generally a better unit. Like anything these day check it good if you buy new, I had to return 3 new shifters last year until I got one that was correct.
You can adjust the them so that's what I would do first. see if the linkage has the levers going completely into gear. If you get the linkage set and still have a problem you might need syncros and sliders in the tranny.
Gary
Old Sep 1, 2004 | 01:17 PM
superfine69's Avatar
superfine69
I have the hurst in my 69 and it shifts much better then my uncles 72 with the stock shifter
Old Sep 1, 2004 | 02:08 PM
Dick72LT1's Avatar
Dick72LT1
I just removed a Hurst Comp plus from my 72 LT1. I'm going the originality route when I replace it. I'm figuring on buying a new shifter and linkage. If you decide to get rid of your original shifter, I'd be interested in buying the mounting bracket. Maybe there are some parts we can swap or sell?
Dick
Oakton, VA
Old Sep 1, 2004 | 02:19 PM
wugak's Avatar
wugak
I plan to keep all original parts for the future just in case, sorry.
I may just end up going Hurst just because. I drove one a few months back and it did feel nice.
To Shifty help
