transmission/clutch/flywheel install ?
Old Sep 2, 2004 | 11:15 AM
70vert's Avatar
70vert
Banned Scam/Spammer
Default transmission/clutch/flywheel install ?
I've got a '70 454/4speed, hooker side exhaust. I need to replace the flywheel; while I'm there I'll relplace the clutch. The book says that it is necessary to tilt the back of the engine down to the point the tack drive cable touches the firewall. This means I would have to remove my headers/side exhaust-a real main in the butt.
From looking at the transmission, bell housing, etc. it really doesn't look like that should be necessary. Has anybody been there before?
Old Sep 2, 2004 | 12:29 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If you can tilt the motor down with the sidepipes attached then you don't need to remove them howver it has to come down quite a bit in order to remove the tranny so you are going to have to at least disconnect the side pipes from the headers, you can get away with leaving the headers on
