68 Steering Column
Old Sep 2, 2004 | 03:20 PM
ROYSREDROCKET's Avatar
ROYSREDROCKET
Default 68 Steering Column
WHILE RESTORING MY 68 VERT I PULLED THE STEERING COLUMN AND FOUND THAT THE BEARINGS AT THE BASE ARE SHOT. IS THERE A REBUILD KIT OUT THERE ,REPAIR SERVICE OR DOES ANYONE OUT THERE HAVE A FUNCTIONAL COLUMN FOR SALE
Old Sep 2, 2004 | 03:30 PM
CGGorman's Avatar
CGGorman
Dr. Rebuild has most of the column parts listed in his catalog.
Old Sep 2, 2004 | 04:35 PM
LemansBlue68's Avatar
LemansBlue68
Contact Long Island Corvette. They specialize in mid-years but the '68 has the same lower bearing as the Late '67. The replacement bearing they provide is a needle bearing affair instead of the ball bearing setup like the original, but once installed you can't tell the difference. Other "replacement" bearings that some other Corvette places provide are modified later model "stepped" bearings that are turned down on one end to fit inside the lower tube of the '68 column. They would work OK but part of the bearing is exposed, is visible, and obviously not correct. LICS's bearing is no more expensive than the cobbled ones at $30.
The original '68 lower bearing is EXTREMELY rare. I looked for a long time for an original until I found LICS's replacement.
To 68 Steering Column
