76 Washer Pump Problem
Old Sep 3, 2004 | 09:48 PM
wmrvette1976's Avatar
wmrvette1976
Default 76 Washer Pump Problem
I recently replaced the washer pump on my car and it worked fine. Then I was doing some work on the console gauge cluster and had the wiper/washer switch disconnected. After reassembly the washer pump no longer works. The wipers still work and there is water in the reservoir. It seems the wiper/washer switch controls both components and there is one fuse for both components so what might I try?
