What type and temperature t-stat is everybody running and what temp does the engine 'run' at? Right now I have a 180 degree cheapo Advance stat and the engine runs about 190. I used to use a Robertshaw and I can't tell any difference between it and the 'stock' one.
I did alot of testing on thermostats. Every other day I would change my thermostat, one day in, one day out. I also monitor each head temperature. My twin electric fans are also manually controled, each one has it's own relay/switch.
I found without a thermostat the heads ran more even temperature, especially after shutting down hot for about 5 minutes and then restarting and driving, the passengers head came down in temp quicker to match the drivers head which always seemed to run a little cooler.
I also found without a thermostat I didn't need to turn on any fans on the highway to maintain about 185 temperature where I feel most comfortable running. In town I use one fan and on hot hot days 2 in town.
With a thermostat I can't get away without a fan on the open road and if I try the temperature creeps to 200 before I know it.
I only run in nice weather, no winter driving.
So after at least a dozen thermostat changes I settled on NO thermostat.
Yeh, Ganey is right of course, and so I found that not being able to buy the older style larger flow diameter t-stats anymore, I just drilled 4 holes around the perimeter, actually in 'winter' here in Florida, that's too many, should be about 2 holes...
at any rate, the smaller diamter flow restriction plates used today only allow for about 195F operation nothing cooler, so that's why the holes...get that flow up there....
Hmmmm 180 huh? I'm so glad this question was asked! I thought it was typical of my corvette to run hottter then other 350's because of the airflow (or lack of airflow) in the corvette styling. My temp gauge gets up to about 205 - 210 before it cools down to about 190-195. Highway driving seems to bring it down a little more, I'm guessing because of more air passing through the radiator. I'm thinking I should check to see what t-stat I have. Maybe I should just replace it when I have it open. My Radiator and fan clutch are both about a year old.
Winter in Florida? That's got my imagination going
I run a 180 stat with a couple of small holes drilled in it. I briefly tried a 160 but didn't get on with it. The coolant seemed to run at a bit of a low temp and, as well as the computer griping about it ('81), I was thinking that the motor has done 70 000 miles running at 195* so dropping it down to 160* may not be such a good thing (OK, the charge density may be higher, more power, etc, but what about the lubrication issues when running at a lower temp? Clearances due to expansion of dissimilar metals?). 180 seems like a good compromise to me. Besides, the performance gained by going to a 160 stat could probably be duplicated by my staying with a 180 stat & not eating as many Jaffa cakes & choc chip cookies
Ok...I noticed a couple of folks metioned having a hole(s) in the t-stat. I have heard of this to help removed trapped air in a system but what other advantage does it have? What size hole are we talking about? Which part is the hole drilled in?
Cheapest way to cool your engine is to remove the T-stat...I found that with a T-stat it took 2 minutes to get my engine to 160ºF and without one it took 5 minutes. A stuck T-stat can destroy an engine, so I suffer the extra 3 minutes of inconvenience for the safety of my engine.
The stuck T stat problem is non existent if you actually buy a QUALITY thermostat, one that remains OPEN when it fails. That's why I'm running the volvo ones. They are about the most rugged stat out there and those swedes know about engine warmup in the climate they live in.
TT may well be right about the volvo stats but he's in Europe, and so they are just generic here....as all others....
thing is, I recall, the larger flow diamter rings are only available on the 160f stats these days....you need check that out...
the differance is like 1 inch even to 1 1/8 inch...close....but drilling the holes makes it up, IF the thing is calibrated to 180f, which all of them are calibrated upward these days, for EPA reasons.....
take a new stat and put it in boiling water with a digital temp probe, and note when it opens and closes....you will find the 160f stats are really 180f, and the 180f are really 195f, and the 195's are hotter yet, too boot anyting but the 160fs have a flow restricting small hole/flange....hense if the valve itself opens and closes in my desired range....180f.....I drill holes, and it's right for the cars.....
case closed, been there doing this for too many years, maybe my memory as to what/when/exact changes is a bit off, but not the overall affect of these changes....and yes, they have changed production over the years....not that any of them will admit it....
Twin okay so the Volvo ones are the best now do they make one that will bolt into our housings? And if so would you by chance have a part number or something so we could find one.
They will probably fit the standard housing with some machining but I have never tried, before the thing you see above I was running a C&R thermostat housing w/ bypass that also had a Volvo unit in it. Don't have a part number, I just go to the volvo dealership and get what they have, I started using the volvo ones because that's what came in my C&R unit and I've stuck with them. They are pretty different from the stockers, here's what they roughly look like:
If you have access to a machine shop it would be pretty straightforward to whip up a small housing to bolt between your manifold and existing thermostat housing
I use 195. My car has no problems cooling. I actually just upped it from 180 because the engine was running so cold that the carb would cough sometimes in cooler weather (it needs tuning).
Have been running a 195 degree year round with no problems. I also drive my car during the winter providing the roads are clear. Max I see during summer is 200 degrees during the high speed stuff. Seems on my car, the 180 is a tad too cold.
I found them at O'Reillys under the "Murray" name, but they are the same. I paid $7.50 for mine. It took about 6 months (and 1 Dallas summer) for it to fail open and my engine temps are normally 190 and never get over 210.
I'm going to go with another one, but if it fails quickly again, I'm going back to the conventional tstat.
