Rear lowering bolt question
Old Sep 7, 2004 | 01:47 AM
PRESSURERAT's Avatar
PRESSURERAT
Default Rear lowering bolt question
How long do the lowering bolts need to be? I'm not sure what stock length is because I'm too lazy to go outside right now and measure them. VB&P sells an 8" bolt for C3's. They have a 10" for the C4's. Is the 8" long enough to lower the rear about an inch or better? How badly will lowering the rear 1" affect the camber? Bad enough to necessitate(sp?) an alignment?
Old Sep 7, 2004 | 03:25 AM
71coupe's Avatar
71coupe
It won't affect the camber. The only thing I don't like about the longer bolt is that is lacks the holes for the cotter pins - they use a lock nut instead. Might be able to drill a small hole in the end for a cotter pin or safety wire.
After I found my upper cntl arms bolts loose, I'm paranoid about bolts loosening now.
Old Sep 7, 2004 | 04:35 AM
stickboy's Avatar
stickboy
The standard bold is about 6" I think, however you might want to measure what you have before ordering. If you have a non-stock spring you might already have the longer bolts. If you do go with longer bolts make sure the tire is not going to hit them, it is also a good idea to make sure that if you have a flat they won't drag on the road.
Old Sep 7, 2004 | 08:48 AM
PRESSURERAT
Top.
Old Sep 7, 2004 | 10:18 AM
Brettmc's Avatar
Brettmc
Just go to a local nut&bolt shop and get some 8" grade 8 bolts with matching nylock nuts. It'll be a lot cheaper than buying them from a vette parts supplier.
Brett
Old Sep 7, 2004 | 01:51 PM
petty44's Avatar
petty44
good luck on finding bolts local I had to order mine from Bolt Depot they were 8" bolts about $20.00 grade 8. hope this helps. bushog
Old Sep 7, 2004 | 04:35 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Standard bolt was 6.5" when I took mine out. I've got the 8" bolts in and dropped all the way. I'd like to be able to drop it another inch or so but as it stands now I only have 2.5-3.0 inches before the trailing arm will hit the bump stop
To Rear lowering bolt question
