Engine Vacuum Leak
Old Sep 8, 2004 | 11:31 PM
Edzred72's Avatar
Edzred72
Default Engine Vacuum Leak
I'm only pulling a steady 12Hg at idel (800rpm) from the intake vac fitting. Stock motor with Performer intake (new gaskets), header sidepipes & Lars rebuilt Q-jet with new carb gasket. Could this be an intake/carb leak...or something else?? If intake...Is there a trick to find exactly where it's leaking? I remember something about spraying a mist of some liquid around the intake/carb and listening for engine changes???????
Eddie
Old Sep 8, 2004 | 11:57 PM
comp's Avatar
comp
starting fluid, Carefully.......
Old Sep 9, 2004 | 12:42 AM
Z-man's Avatar
Z-man
Spray it around places that might be leaking. If you hit a vacuum leak, the fluid will be drawn in to the engine, and it will rev up...
Old Sep 9, 2004 | 11:16 AM
Edzred72's Avatar
Edzred72
Thanks for the advise guys...but could anything other than an intake leak/carb leak/radical cam cause low vacuum???
Eddie
To Engine Vacuum Leak
