Help wanted- my Japanese Corvette
Had a look at the new C3 and thre is good and bad.
1. Chassis is rust free - but cracked around the coil spring holder on the drivers side, and the bottom wishbone mount on the other side - no hassle here - just a welding job I think.
2. Steering and suspension rubbers / mounts are all shot - new ones should cure it all.
3. Now the problems.........
4. How do I tell a 48 from an 82 ??
5. It has a new Holley - the only markings I can see are P80 - what is this ???
6. Manifold is an Edelbrock torker - is this good or bad for this engine ??
7. Headers turn out to be "shorties" finish at the first flange - so the thermocouple and flapper valve are still there.
8. These shorties are connected through 2 1/2 pipes to the centre box - 2-1-2 style .
So is that centre box a cat ????
9. There is an elecrtic fan between the rad and factory metal fan - is that an extra or factory - cos if its an extra - its very well done. ??
An thinking of twin electric fans anyway.
10. Looks like the heads and lower half are untouched - bolts still oil encrusted etc, so possibly no cam change.
Anyone tell me of a good cam taking the holley and torker into account ??
11. Any thoughts or anyone done the L98 ally heads change - how good an upgrade is it ??
Need all help today , asap .
Thanks to all.
Hugo.
I'm not sure but I don't think I'd weld the lower control arm....get new one's. At least that's what I would do.
What size engine do you have? 350? 427-424-502??
An electric fan was not factory on any C3. Normally when an electric fan is installed the engine fan is removed.
Hi, Yeah, I think he means L-48 or L-82 and not to start anything,,,,,,,,,,,,but electric fans were factory, my late great '80 ( L-82) has one! Peace,,,,,,,,,,,,,,,Craig
SEE http://forums.corvetteforum.com/showthread.php?t=898700
Evidently he has a 78 350 auto- EDIT now it's 81 350 auto.
7 & 8 Exhaust- SEE what many refer to as my Exhaust topic.
http://www.corvettefaq.com/c3/ganeyexhaust.htm
9 The el. fan was factory on some later A/C cars. No need for more.
11 Sounds fine for you.
10 Not necessarily, intake needs to be pulled for cam, not heads.
Evidently you need to do intake first as this could fix you up, then report back. Cam- sounds like you would like HE 260H or XE256.
Still need to know more before the end of the day - can anyone give me the phone number of a specialised 350 engine builder so I can chat over my problems ??
Cheers,
Hugo
1966 CA-delivered Corvettes, except for the L-72, used the A.I.R. (RPO K-19) system
1967 CA-delivered Corvettes, used the A.I.R. (RPO K-19) system.
1968 & 1969, ALL Corvettes used the A.I.R. system regardless of engine, transmission, or where delivered.
1970, Chevrolet went to the CCS (Controlled Combustion System) for emissions control on most Corvettes, except the LT-1s.
1971, Corvettes continued to use CCS (except LT-1s and LS-6s).
1972, A.I.R. system returned for most Corvettes except engines except L48s with the "CKW" and "CKX" code.
1973 - 1975, all Corvettes used A.I.R, except for the 1974 L48 with automatic and Federal emissions which used CCS.
1976, all Corvettes returned to CCS, except California-certified cars which used A.I.R.
1977, all Corvettes used CCS, except California and "High Altitude" delivered cars which used A.I.R.
1978 & 1979 all Corvettes used CCS, except California cars, "high altitude" and all L-82s which used A.I.R. L-82s were not available in California or "high altitude" areas during these years.
1980 - 1987, all Corvettes used A.I.R.
1988 - on, A.I.R. was used on most, if not all Corvettes, although many C4s use an electric air pump.
Good details on AIR in the thread, gliot1 is spot on with the L-48 vs L-82 bit, although 79 L-48s had dual snorkel air intakes as well.
the manifold and carburator are obviously aftermarket. the fact that you have headers complete with the butterfly valve indicates that you either have the very crappy stock exhaust or a really well done aftermarket exaust. because you said it still does the 2-1-2, i'll assume it's the former.
if the exhaust is factory, you could not possibly have a worse combination for performance. the stock exhaust is beyond lousy and woefully incapable of flowing like what a holley and single plane mainfold would require.
one thing you need to tell us is about your distributor. take a look at it and tell us if there is a vacuum advance canister on it. it should be a kind of silver cone shaped thing mounted on the base of the distributor and pointing toward the A/C compressor (if you still have one). if you have an '81 with a holley but you don't have that type of distributor, your screwed.
what we need to give you the best is your VIN. you can leave out the last 4 or 5 numbers for your own privacy if you like. just put in 'xxxx' instead of the numbers.
also, there should be two codes stamped into the block pad on the right side of the engine just in front of the head. if it's that old and unmolested, you'll probably need to dump a bunch of degreaser and scrub it with a brush to see it. one code will have the same last few numbers as your VIN. if it doesn't, it's not the original engine.
finally, if you have a way to post a picture of the engine, that would really provide us with some clues.
i understand you want to get some power and all but the first things i would do, if i were you, would be identify what you actually have. if your not restricted by smog laws, take the factory exhaust down to the nearest body of water and make a new artifical reef. then, replace that single plane manifold with a good dual plane and you'll be well on your way to having good street power.
electric fans are definately a plus (sorry Ganey). the reduction of rotational mass and parasitic loss is well worth the money. almost like a free 10hp. but please, do NOT buy engine parts from ecklers/MAM/etc, etc. go to jegs or summit. you'll save yourself half the pricing.
again, sorry Ganey, but there was definately something wrong with some of the engines between '72 and '90. more specifically, the cams used by GM in the late '70s through the early '80s were notorious for wiping out lobes, and doing so in relatively short order. before my overhaul 2 or 3 years ago, most people were amazed i still had the factory cam in my car at 100k miles. when i did pull the cam at 140k miles, there were at least 4 lobes in various stages of disintegration.
lastly, maybe i missed another thread but how about some more details about what you know of this car. do i understand this right? the car came from japan and now resides in jolly ole england with you?
My eyes are square from reading things up on the net - and all seems to agree about the exhaust etc - luckily I can see the sea from my window - its about 600 feet away !! One reef coming up !!
Anyway - numbers....Vinis.
161AY876(G)XB5108677 - its either a 6 or a G,
Block stamps,
V0814ZDD, and
1B54-(1) (7) -08677 - its either a badly done 4 or 1 or 7.
Vacuum advance is there and working well.
All emission stuff is gone - engine is as bare as a babies bum !!
Curiously, the choke plate is missing from the top of the Holley and it starts up and idles from cold too well - so indicating as rich as hell - the exhaust and the back of the car ( black soot ) confirm this - as did the phone call from visa to ask if my card had been stolen ( this is true ) cos I bought 3 tanks of gas in 5 hours to get home !!!!!!!
Now you know why I need the help - this Vette is increasing the UK's National Debt - in gas.
The second digid in yours is a G not 6 for GM
The ninth digit is probably a 6 not a G and I think that is just a random check digit
The eleventh digit is probably a S for St. Louis (assembly plant).
Or somewhere close to that. It looks like that is the original engine the ZDD it the 195 hp with the XXXXX matching on the block. Hope someone else chimes in that knows more about the vin, I'm not really sure but should be close.
Hope this helps.
YBnormal...drive a vette
Any comments or observations about which might be better..........?
Have noticed with the 255-70-15 BFG's on there at the moment - there is a little ( one eigth ) scuff line caused by the rear spring catching on occasions - but it may have been from turning while jacked up.
Out of interest - prices here seem reasonable - the 255-60-15 Avons are £64 fitted and balanced - about $112 ?? - seems OK.
C ya,
Hugo.
PS, Why have Ecklers dropped so much of the engine and mechanical stuff - not even a HD oil pump anymore ....!!
Thanks & you bring up a very good point to check dist.
Electric fans are fine. I don't type & was tring to keep it short. I fix things fast & it was more a matter of prioritys w/ all the issues here.
A few:
1. Gas consumption is horrendous - at 85mph I am getting about 10 mpg to a Uk gallon - about 8 to a US.
4. As I live in West Wales - max temp about 75 degrees on a good day and bloody cold at all other times - I am thinking of changing to twin electric fans as per the Ecklers catalogue - any comments.
http://performanceunlimited.com/docu...ancompare.html
7. Re gas consumption -
Then he has to find out which carb he has, etc.-
hensen1954
do a topic on that.
Anyway the engines are fine. If a sto*k cam will get it home for a cam change that works for me.
C ya,
Hugo.
