I have a '69 427 with a 3x2 setup. The timing is 14 degress with 38 total. It's been sluggish on take off so I pulled all the plugs to take a look. A couple were carbon fouled and others were light grey. I cleaned all the plugs up and reinstalled. I went for a 30 mile drive and started to experience the sluggish take off about halfway through the trip after idling at stoplights. I pulled the plugs when I got home and found this.
1-light brown
2-carbon fouled
3-oil&carbon fouled
4-carbon fouled
5-light brown
6-light brown
7-light grey
8-almost white
I've only had the car a couple of months and had a heck of a time getting it to pass emissions. I know the carb is running rich because the jetting is set up sea level and I live at about 6000' of elevation. I haven't gotten around to rejetting the carbs yet.
My question is this, does it seem like I have a major problem with the engine? I know that oil fouling is due to worn rings or blowby from the valve guides. I haven't done a compression test yet but I will this weekend.
Definitely do a compression test and cmpare the reading to the spark plugs. I would expect lower readings on 2,3,4, & 8, they look suspicious to internal engine problems. 8 - could be coolant being burned up in the cumbustion chamber (ie possible head gasket problems). How many miles on the engine?
Rejetting may cure 2, 3, 4, but carb rebuilding may be the better intial start if it has many miles on it.
History of the car is sketchy at best so I don't know much. I was told that the engine was rebuilt about 10k miles ago but I have my doubts. I know it sat for most of the past 2 years before I bought it. It only was driven 1900 miles since the previous owner titled the car. It's showing just over 51k right now for what it's worth.
I've put about 900 miles on it the past 2 months and it seems to be getting worse. I was hoping to put off the rebuild until the winter. Bummer.
I'll get the compression tests done this weekend.
Thanks for the help.
Dave
