Torque Converter suggestions?
Old Sep 11, 2004 | 05:12 PM
joe73vette's Avatar
joe73vette
Default Torque Converter suggestions?
This winter I am going to rebuild the motor and TH400 tranny. I know there are better torque conveters out there than the $100 rebuilt that is in there now. I heard you can get converters that stall at around 2400 under full throttle, but are not at all sloppy at part throttle or cruising on the highway. Any experiences out there? I am going for a mild upgrade with 212/218@.050 crane cam - 350 hp, 400 lbs ft, 3.08 gears, daily driver with highway miles.
Continental is one of the brands I have heard about. Also Hughes and Vigilante. What about the B&M converters?
Joe
Old Sep 11, 2004 | 05:29 PM
GTR1999's Avatar
GTR1999
Hey Joe,
Sounds like we're doing the same thing. I already finished the TH400 rebuild,and the differential using new 308's. I will start the engine this Winter. I'm using the original 350-200 engine out of my 72. Going to use Comp 260H cam WP S/R Torquers heads(67cc) headers,Performer intake,stock distributor.
I haven't choosen a Converter yet,but I'm thinking around a 2000 stall is all I need. B&M,TCI, or something from the tranny supplier.
Let me know what you choose.
Gary
Old Sep 11, 2004 | 05:56 PM
73jst4fun's Avatar
73jst4fun
Big differance in converter quality, after doing some research and looking at some converters and their construction I went with the TCI "breakaway" model for my THD400 trans. It's about 2,000 stall, with 3.55 gearing it's working good....
Old Sep 11, 2004 | 06:26 PM
EDDIEJ82's Avatar
EDDIEJ82
I just ordered a Vigilanti 3600 for my 700 yesterday. They looked to be on of the best on the market from the research I did
Old Sep 11, 2004 | 06:40 PM
comp's Avatar
comp
you need to talk to them about your combo. where will your power band be etc.
Old Sep 11, 2004 | 06:45 PM
VETDRMS's Avatar
VETDRMS
My 4000rpm stall converter from Torco drives just fine around town, and cruising down the highway at 2800rpm. No excessive heat (unless your beating on it), and part throttle and slow speed driving is not an issue...at all.
www.torcoconverters.com is the site.
Old Sep 12, 2004 | 12:41 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Wow, I thought a 2200 was too sloppy on the street for me.
Anyway, check out ckpeformance.com as a comparison in your search.
Old Sep 12, 2004 | 12:08 PM
joe73vette's Avatar
joe73vette
Thanks for the help, but the website redirects to http://avalon.camalott.com/ so I can't get there. Any idea for pricing? Stall speeds?
Anyway, check out ckpeformance.com as a comparison in your search.:
That looks promising, but I couldn't find descriptions of the different converters, just a price list. What did you get, because if you think it was too sloppy, I am probably not going to get that one.
Originally Posted by 73jst4fun
Big differance in converter quality, after doing some research and looking at some converters and their construction I went with the TCI "breakaway" model for my THD400 trans. It's about 2,000 stall, with 3.55 gearing it's working good.... .:
Do you think it is sloppy around town? I don't want to kill the low end punch at low speeds, that's half the fun with a torquey motor.
Thanks to all
Joe
Old Sep 12, 2004 | 06:01 PM
AlwaysWave's Avatar
AlwaysWave
Thanks to all
Joe
I bought the 1300 - 1700, the 2nd one on their list. For my almost stock engine, it's much better than the 2200 BowTie gave me.
http://ckperformance.com/gm_200R4_convert.html
Old Sep 12, 2004 | 10:08 PM
Glensgages's Avatar
Glensgages
I last had my Z28 on the street (for all-of 170+ miles...) in '98, and I got a converter for the THM400 from ATI.
It is an 8" converter, built for the street, and in normal driving, you almost don't know that it is a race-quality piece...
but once you bring the motor 'up-against' it, it slips like my 'race-only' Transmission-Specialties sprag-less jobbie.
Better-still, the trans-fluid doesn't get hot at-all in normal driving, and at 50 MPH, it feels 'tight'.
The car runs 12-eighties with either converter:
it is a bit more consistent/predictable with the TS, but MPHs higher with the ATI (as high as 109 vs. 105).
Both pieces are bullet-proof, and cost approx $600+ each.
Old Sep 13, 2004 | 12:57 AM
isosceles's Avatar
isosceles
the 1800 stall convertor I put in with my 200r4 seems too tight. I can't tell much of a difference from stock.
To Torque Converter suggestions?
