Sporadic Oil Pressure?
Old Sep 12, 2004 | 06:33 PM
CrossedFlags77's Avatar
CrossedFlags77
Default Sporadic Oil Pressure?
I have been having a problem for the last couple of days with my oil pressure. It has seemed somewhat sporadic and relatively low. It is really low around 5 psi when I just leisurely accelerate and sometimes goes all the way to 0 psi. So I am getting scared. It runs fine and idles fine it just has low/sporadic oil pressure. What I mean by sporadic is that the needle just jumps all over the place and stays in the same spot for a little bit then will jump around alot. There is no method to its madness. It has been sporadic for a while but it hasnt ever been showing low pressure like it has been lately. Is my oil pressure sensor going bad or is it my pump going bad? Any help would be appreciated.
Ryan
Old Sep 12, 2004 | 06:34 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Make sure the wire is connected to the sender correctly at the back of the block, sound like it's loose
Old Sep 12, 2004 | 06:47 PM
CrossedFlags77
It is I checked it earlier.
Old Sep 12, 2004 | 07:29 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Could be the sensor is going out to lunch.
Old Sep 12, 2004 | 08:19 PM
Crash80's Avatar
Crash80
Not to sound like a wise ***, but have you checked your dipstick lately? Last time my oil pressure jumped about I was low on oil. That would be an easy fix now wouldn't it?
Old Sep 12, 2004 | 08:35 PM
CrossedFlags77
I checked it and its all good. I am picking up an oil pressure sensor right now so we will see how it goes once I get it installed.
To Sporadic Oil Pressure?
