Heating Unit repair
Old Sep 12, 2004 | 08:06 PM
OneBrokenSmile07's Avatar
OneBrokenSmile07
Default Heating Unit repair
Ive noticed that my heat/air vents on the console and dash don't work. When I turn the heat on it comes out by the kick panels down below just fine, but none of the other vents work. I don't know if there is just a lose cable or something somewhere, has this happened to anyone? Know how to fix it?
Old Sep 13, 2004 | 06:59 PM
OneBrokenSmile07
bump
Old Sep 13, 2004 | 07:06 PM
Ganey's Avatar
Ganey
The problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine is damaged from heat - a small plastic tube that goes in below the hood theft switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease or vasoline to fix.
3) If you have a heater, the small hose to heater hose valve underhood probably also needs replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends.
Old Sep 14, 2004 | 08:20 AM
Pete76Shark's Avatar
Pete76Shark
After you do what Ganey suggests, then I would..
You might have a vac leak where the vac tubes connect into the climate control panel. Suggest you remove the panel and make sure all of the vac lines are connected like they should be.
This happened to me and the vent doors went to the default position and stayed there.
To Heating Unit repair
