Cranking Compression Issue Resolved
Someone mentioned that range was low for a performance motor. I used to have 190-195 with the XE262 but that cam had very different timing events. The intake valve was open for only 32 degrees and closed 7.5 degrees sooner (35 vs 42.5) on a 106 ICA. The ISKY is open for 44 degrees and closes at 42.5 on a 112 ICA. So it's just not going to build the same big cylinder pressure. Plus it's a 9.5:1 CR max.
